Ford pinion gear fresh out of the bead blaster. Keyway looks good. The bore has some minor pitting as does a few of the teeth. I have tried to show the worst of the pitting on the teeth. Teeth profile look good and there are no chipped teeth.
$40 plus USPS Flat Rate shipping
Scott Elliott
971-5O6-94O2
FS: Pinion Gear 11 tooth
Topic author - Posts: 329
- Last Name: Elliott
- * REQUIRED* Type and Year of Model Ts owned: 1923 Mercury speedster replica, 1923 speedster
Re: FS: Pinion Gear 11 tooth
$25 plus shipping
