SOLD
This is an ingenious item. It looks partially manufactured and partially home made. It is a great “wall hanger” just as it is. It would require complete restoration to use (disassemble, clean, lubricate, and adjust to use). It was on an air compressor outfit that used 2 T motors connected front to rear. The front motor was power and the rear motor was the compressor and it was so brilliantly made it had to be constructed from some plans that were available back in the day. Note: This is an item for those of appropriate skill level. If you don’t understand exactly how it works, how it mounts, and how it connects to the carb just by looking at the photo, you should not expect that you will be able to restore, install, and use it…
Email if you want it. First $60 gets it and FREE SHIPPING inside the USA. Please do not post here or pm. Thanks!
Sold:
Topic author - Posts: 1550
- First Name: Adam
- Last Name: Doleshal
