a raw unmachined brass casting, that I believe was intended to be a gas cap for a brass-era speedster. The OD is approx. 2.7", and the walls are 0.14" thick at the bottom. They taper inward so they get thicker as you go up, leaving plenty of room to cut threads. The overall height is 1.57" approx. Nice heavy cast brass, this should look pretty good with some work. I have 4 of these available. Asking $10 each not including Shipping.
Raw Casting for Speedster Gas Cap Yellow Brass $10
Rodger Erickson
Topic author - Posts: 501
- First Name: Rodger
- Last Name: Erickson
- * REQUIRED* Type and Year of Model Ts owned: 1920 Speedster
Rodger Erickson
Re: Raw Casting for Speedster Gas Cap Yellow Brass $10
All of these are spoken for.
Thanks MTFCA.
Thanks MTFCA.
