FS- Ford 5Z-210 Flywheel Bolt Wrench
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Fri Jan 30, 2026 10:16 pm
For Sale- Ford 5Z-210 Flywheel Bolt Wrench. This is the wrench you need to remove or tighten the four flywheel bolts that hold the flywheel to the crankshaft flange. The offset makes getting behind the magnet bolts easy. $30.00 + $12.00 USPS shipping.
PP or check. Please PM or e-mail to DMCGEARSatYAHOOdotCOM. Thanks!
