I have 3 or each, not matching but all have nice teeth and the pinion gears look good at the taper and keyway.
$150 per R&P including shipping to USA 48
$400 for all including shipping.
Please call or text me at 33zero 3nine one nine zero 62 Dave
Used Ring and pinion gears FS
Ruxstel24
Topic author - Posts: 2406
- Last Name: Hanlon
Ruxstel24
- Last Name: Hanlon
Re: Used Ring and pinion gears FS
To the top…
If you cleaned them up, so folks could see the condition of the gear teeth, you might be able to sell these.
Ruxstel24
- Last Name: Hanlon
I agree but my wire wheel is outside in the cold.Jerry VanOoteghem wrote: ↑Fri Feb 06, 2026 9:05 amIf you cleaned them up, so folks could see the condition of the gear teeth, you might be able to sell these.
Supposed to be in the 40s next week and I will.
I can certainly sympathize with that.Ruxstel24 wrote: ↑Fri Feb 06, 2026 9:31 amI agree but my wire wheel is outside in the cold.Jerry VanOoteghem wrote: ↑Fri Feb 06, 2026 9:05 amIf you cleaned them up, so folks could see the condition of the gear teeth, you might be able to sell these.
