Transmission driven gear puller. Broke on pulling off a very stubborn repro driven gear. Worked like a champ before. Cost is zero. You pay Priority postage. Email me via the website.
Richard Gould
Free to good welder, spoken for
RGould1910
Topic author - Posts: 1246
- Last Name: Gould
Re: Free to good welder
For anyone in the future:
This puller is a cam gear puller 5Z320 and was for pulling the small timing gear off the end of crankshafts
The 5Z326 Transmission Gear Puller looks just like this but doesn't have the raised lip at the tip
I have several that have that same undercut on the arms. They all fit the driven gear. Mine are all numbered 3Z611.Scott_Conger wrote: ↑Sat Mar 07, 2026 2:45 pmFor anyone in the future:
If you squeeze the arms together a bit & remove the big chunk of steel off the screw it will work as a very good puller for rear wire wheel hubs.
Rodger Erickson
- First Name: Rodger
- Last Name: Erickson
- * REQUIRED* Type and Year of Model Ts owned: 1920 Speedster
Regarding rear wire wheel hub pullers, I've had success with a Harbor Freight Tie Rod and Pitman Arm Puller ($13.99.) You will need to grind off the insides of the tips by just a small amount to slide into the groove. Nobody should ever have to feel guilty about grinding, hacking, tweaking, or wrecking Harbor Freight tools.
RGould1910
- Last Name: Gould
Re: Free to good welder, spoken for
Thanks for the clarification Scott. New info for me.
