I have @1921 engine and I have a new copper manifold gasket. Do I need the copper rings for the exhaust manifold? Do I use lock washers on the nuts holding the manifolds to the cylinder head?
Thanks,
Campbell Tellman
1916 Ford Touring
Beaufort, NC
manifold gasket rings
Campbell Tellman
Topic author - Posts: 71
- First Name: Campbell
- Last Name: Tellman
- * REQUIRED* Type and Year of Model Ts owned: 1916 Ford Touring
Re: manifold gasket rings
All six ports use a copper crush ring with the steel gland rings IF your exhaust manifold is straight ! This should be in the regular discussion forum.
- Last Name: House
I agree with Steve’s first sentence. Altho I’ve never seen or personally used lock washers on the 4 manifold studs, I don’t suppose it’d hurt
