26-7 Fan Hub removal.
Cigarboxrob
Last Name: Frankel
Post by Cigarboxrob » Sun May 17, 2020 9:29 am
...Howdy, Fellers and Gals!
After a lot of wiggle room, my fan hub sounds like a jackhammer. I ordered the sealed bearing hub from Snyder’s-Who had it to me in record time. Noting the nut on the back of the shaft, I can’t seem to figure out how to remove the pulley. A socket on the end just spins the internals. Any input would be appreciated! Thanks!
Last Name: Gregush
Re: 26-7 Fan Hub removal.
Post by Mark Gregush » Sun May 17, 2020 9:33 am
You have to take the fan off the pulley, there are flats on the shaft under it.
Cigarboxrob
Last Name: Frankel
Post by Cigarboxrob » Sun May 17, 2020 10:00 am
....I’ll double check! It appears the only way to remove the fan is to remove the water neck from the block as a complete assembly as it’s just too close to the radiator to access those screws! I’d normally do that, but I don’t have a replacement gasket on hand and I’d like to drive the old girl today!
Last Name: Gregush
Post by Mark Gregush » Sun May 17, 2020 10:11 am
Make your own out of a cereal box. ;)
jab35
Last Name: Bartsch
Post by jab35 » Sun May 17, 2020 10:38 am
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Sun May 17, 2020 10:42 am
Dont forget to inspect the fan for cracks. The 27 I am working on for a friend had a crack that was painted over. I found it when I had the radiator out.
Post by DanTreace » Sun May 17, 2020 10:56 am
Unless it's rusted in place, you should be able to remove the eccentric from the rear, after you release the nut on the fan shaft.
Then the fan shaft with the fan should drop down and out through the slot in the bottom of the fan bracket. The longer fan pulley for the late thin row radiator complicates things.
Post by TRDxB2 » Sun May 17, 2020 11:10 am
Chances are the Fan Shaft is worn and the bearing hub will be a loose fit and it needs to be replaced as well. Also you might need a washer to compensate for the felt washer which is no longer needed. I found one of the correct ID, thickness and OD that fits inside the fan shaft cap.
Post by Norman Kling » Sun May 17, 2020 11:19 am
Very likely easiest way would be to remove the radiator first. Then you can remove the blade and or remove as in the picture by Dan. You will need to remove the fan anyway to remove the shaft.
Cigarboxrob
Last Name: Frankel
Post by Cigarboxrob » Sun May 17, 2020 11:23 am
...Gentlemen, I thank you immensely!
...I’ve just sprayed the shaft with PB and tapped a few times. I’ll let that sit and stick a 3/8 on the shaft...I have a bin of washers somewhere in this mess of a garage, so I’m sure I’ll find one that fits. It looks like this can’t be done: “In-Car,” so I may just try the cereal box trick for a gasket!
Last Name: Gregush
Post by Mark Gregush » Sun May 17, 2020 2:34 pm
I was meaning the gasket between the water outlet and head if you took it off. With the sealed bearings in the hub, you will not need a gasket between the hub and fan.
From Lang's catalog;
Fan hub ball bearing accessory pulley, All new, machined aluminum. 2 sealed ball bearings, No oiling or greasing required, no exchange required. Modified with modern style ball bearings. NOTE: Ball bearing fan hubs use permanently lubricated, sealed bearings. No more grease all over your engine and hood!
Matt in California
First Name: Matt
Last Name: G
* REQUIRED* Type and Year of Model Ts owned: 1926 Touring, 1926 Fordor Project, TT C-cab flatbed farm field find, TT dump truck project
Post by Matt in California » Sun May 17, 2020 2:44 pm
I have never tried that! Does it work well?
Matt
Last Name: Gregush
Post by Mark Gregush » Sun May 17, 2020 2:54 pm
The gaskets you get from the suppliers may be a little thicker but are just plant fiber.
Matt in California
First Name: Matt
Last Name: G
Post by Matt in California » Sun May 17, 2020 3:24 pm
Mark
I know gaskets are cheap, but I like the idea if I am in a pinch. (And if I just need a gasket shipping can be expensive.)
Matt
Post by RajoRacer » Sun May 17, 2020 3:48 pm
Weren't "ballpein" hammers made for gasket cutting ?????
Matt in California
First Name: Matt
Last Name: G
Post by Matt in California » Tue May 19, 2020 12:05 pm
I like to learn something every day. For those, like me, who never saw the ball peen gasket making here is a good example:
https://youtu.be/QvoI6A73fi0
Matt
Cigarboxrob
Last Name: Frankel
Post by Cigarboxrob » Mon Jun 15, 2020 7:21 pm
....So, I ordered a new fan shaft from Snyder’s....The two ball bearing job that’s sealed.
...Snyder’s cautioned me about the shaft; Sure enough, the new shaft won’t slide in. Too thick.
....Without a lathe, any suggestions how to turn the shaft to fit? Thanks in advance!
Post by DanTreace » Mon Jun 15, 2020 8:39 pm
If you only need a few thousands off the new shaft, try sanding it down. Fit the threaded end into your power drill chuck, mount the drill in your vise jaws. Spin the shaft at good speed holding a folded over length of fine crocus cloth about 3/4" wide, several inches long to then pull it back and forth over the spinning shaft. Check often to test fit. Poor man's lathe :)
Post by TRDxB2 » Mon Jun 15, 2020 8:54 pm
Before you or someone else does something, remember the shaft can be a tight fit into the sealed bearing hub. What is the OD of the shaft and IF of the Hub. Depending on the difference you may need to take to a local machine shop.
Cigarboxrob
Last Name: Frankel
Post by Cigarboxrob » Tue Jun 16, 2020 8:30 pm
....Ready for this?
....After struggling and fighting with the “new” shaft, I took the old one, checked for bends under a laser, and “plonk!” It slid right in the new hub.
....Go figure.
....To anyone who’s ever done a ball bearing hub in a 26-7, what did you use as a spacer between the hub and shaft near the engine block fitting? I’m just trying to save a lot of trial and error! Thanks in advance!
Post by TRDxB2 » Tue Jun 16, 2020 9:42 pm
Using the stock hub as example: I found a thrust washer the same size as the brass bushing (OD/ID) and was thick enough to cover the shaft end and fit inside the fan shaft cap. The purpose is to prevent the bearing bushing from spinning. True Value hardware stores with those multiple part trays will have them.
