Battery charger
Bill Thompson
First Name: Bill
Last Name: Thompson
* REQUIRED* Type and Year of Model Ts owned: 1924 Tudor sedan
Battery charger
Post by Bill Thompson » Wed Jul 29, 2020 7:35 pm
Can anyone recommend a battery charger that will last? I had one for 30 years, it finally died. The last two I bought didn’t even last a full year.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Re: Battery charger
Post by ThreePedalTapDancer » Wed Jul 29, 2020 7:47 pm
I bought this Schumacher, it is pretty nice, 6/12 volt, and has different settings for different types of batteries. It also tells you right away off a battery is sulfated and no good. It automatically turns off and reverts to maintenance charge. It tells you the current charge, as well as flashes the charge percentage as it increases
Last Name: Wrenn
Re: Battery charger
Post by TWrenn » Wed Jul 29, 2020 8:57 pm
I can't attest to what the longevity will be, but I really like this little guy. It's hard to find a 6/12 Volt charger that doesn't cost an arm and a leg. $19.95 at Menards for this one. Cuts itself down to trickle charge too, so if you forget it for a day it won't fry the battery.
Novice
First Name: Jim
Last Name: Davis
Re: Battery charger
Post by Novice » Thu Jul 30, 2020 10:31 am
I have a traveller BCS-2 from TS. it is 6 amp on 6 volt and 6 amp and 2 amp trickle on 12 volt. had it for several years no problem only draw back it is not automatic shut off.
Just goggle automotive battery chargers and there are a number of 6/12/volt still being made.such as the ultra below picture didn't post.
Ultra Performance 2/6 Amp 6/12-Volt Manual Battery Charger
Electrical Rating: 120VAC, 60Hz, 105W.
Charge Settings: 6A, 12V; 2A, 12V; 2A, 6V.
Battery Cables: SPT-2 4 1/2 ft. 18 AWG.
Automatically switches to trickle charge mode after battery is fully charged.
Self-resetting circuit breaker.
View all highlights
John.Zibell
Last Name: Zibell
Re: Battery charger
Post by John.Zibell » Thu Jul 30, 2020 10:44 am
Ive been using these for years. Charges both 6 and 12 volt batteries. https://www.cyclegear.com/accessories/m ... maintainer
1926 Tudor
kelly mt
Last Name: Kelly
Re: Battery charger
Post by kelly mt » Thu Jul 30, 2020 10:50 am
Find one of these, been in service for 70+ years.
OilyBill
First Name: William
Last Name: May
Re: Battery charger
Post by OilyBill » Thu Jul 30, 2020 11:20 am
Look for one of the new ones that has an anti-sulfation or "Recondition" feature.
Repeated heavy discharges and recharges will kill a battery that is not made for them, very quickly.
Take a look at the "CTEK" brand. Made in Sweden, and has excellent reviews.
I bought a "CTEK" one for my motorcycle batteries, and now I use it instead of my regular charger (Which has worked fine for 20 years and is still good, but it doesn't have the "Recondition" mode in the charging cycle)
