Best way to remove drum rivets?
Post by Steve Jelf » Fri Jul 31, 2020 5:29 pm
I aim to replace my broken low drum with a new one from Dave Nolting. I will need to send him a gear from an old drum. What is the best way to remove the rivets without damaging the hub? I think I know, but maybe somebody has a better procedure than I have in mind.
John bevardos
Last Name: bevardos
* REQUIRED* Type and Year of Model Ts owned: Roadster, Coupe, pickup truck, 2-door
Re: Best way to remove drum rivets?
Post by John bevardos » Fri Jul 31, 2020 5:36 pm
Steve,
I drilled them out and used a drift to gently tap them out.
john
Who's still makes these gaskets, I might be in the market for a solid copper one myself.
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Fri Jul 31, 2020 6:36 pm
I use a center drill then drift after.
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Fri Jul 31, 2020 8:06 pm
I think he might have a fixture for removing them. Call and ask if it would cost any more to have him remove it.
R.V.Anderson
First Name: R.V.
Last Name: Anderson
* REQUIRED* Type and Year of Model Ts owned: 1914, 1920, 1923, 1923
Post by R.V.Anderson » Fri Jul 31, 2020 8:32 pm
I think Adam is right. I know that back when Herman Harder was making the drums, he told me that when sending him an original gear, if the drum it was coming off of was worn out or broken, to just take a heavy hammer and break the cast iron away from the gear, leaving the rivets in place, and then send it on in.
Post by Allan » Fri Jul 31, 2020 9:07 pm
I drill them from the countersunk side with a drill somewhat smaller than the rivet stem. I don't go all the way through. then a pin punch will do the rest. The almost cut through countersunk will break off as the rivet stem is driven out.
Stephen_heatherly
First Name: Stephen
Last Name: Heatherly
Post by Stephen_heatherly » Sat Aug 01, 2020 1:51 pm
I just bust the old drum off with a hammer.
Stephen
