T-6574-X removal...
NU2theT
Last Name: Wendt
T-6574-X removal...
Post by NU2theT » Sun Aug 23, 2020 12:12 pm
I needed to remove my old head lamp sockets from the housings and found that the pictured 1/4" drive 1/2" deep socket fit perfect to drive it down with out damaging the head lamp shell.
Jim_PTC_GA
Last Name: Fisher
* REQUIRED* Type and Year of Model Ts owned: 1924, 1925-ish
Re: T-6574-X removal...
Post by Jim_PTC_GA » Sat Aug 29, 2020 2:40 pm
I'm so glad you posted this. I found myself this morning wondering how to replace a damaged one on the T I'm rebuilding and remembered this post. Thank you for taking the time to post it.
Just give me time to Rust and I'll be good as new. :) Wabi-Sabi
Post by John kuehn » Sat Aug 29, 2020 3:10 pm
Using some WD-40 to lube the socket really helps in removing the socket from the shell.
I then used a rubber hammer carefully to loosen it and simply pushed it out by hand.
NU2theT
Last Name: Wendt
Post by NU2theT » Sat Aug 29, 2020 9:56 pm
It's rewarding to know this little tip help someone else. I had sprayed the socket housings the day prior with the PB blaster, as you can see mine were pretty rusty.
