Facing rode
D.Yoder
- First Name: DEAN
- Last Name: YODER
- * REQUIRED* Type and Year of Model Ts owned: 19tour,24tour,25rdpu,27rd.26coupe,TT's,& tractor conversions
Facing rode
I made a new fixture for more accurate machining rods face.
Re: Facing rode
Facing the rod is better than facing the music.
DLodge
- First Name: Dick
- Last Name: Lodge
Re: Facing rode
Or sparing the rod and running the risk of spoiling the child.
				Rich Bingham
- First Name: Rich
- Last Name: Bingham
RustyFords
- First Name: Don
- Last Name: Allen
Re: Facing rode
Dean, do you not face the rods and caps as a pair?
D.Yoder
- First Name: DEAN
- Last Name: YODER
Re: Facing rode
Allan, I am trying facing indexing on the rod bolt holes.  More work but I think more accurate.
Re: Facing rode
Dean, I presume your fixture will allow you to perform the same machining on the rod. I would be interested to know how the two match up after separate operations. A very handy old time garage owner I had the pleasure of finding some T bits for made a fixture to hold an assembled rod to a faceplate in his lathe. He'd bore the rod and chamfer/face one side in one setting, then turn the rod to machine the width and the second chamfer. My lathe is not big enough to swing a rod, or I would have a go at it.
D.Yoder
- First Name: DEAN
- Last Name: YODER
Re: Facing rode
Allan,  The rod and cap mate up perfectly .  I set my jig for 1.490 because if the rod bolt is  not perfectly perpendicular to the mating surface of the rod and cap it changes the thrust thickness. Ford specks are 1.480-1.490
