Were these standard on tube stems?
Fozz71
Last Name: Chochole
Board Member Since: 2003
Post by Fozz71 » Mon Feb 18, 2019 3:05 pm
I found a bunch of these and my car had three on four of the tube stems, I wanted to ask if this was standard Ford equipment and should be on every stem?
Thanks, Jim
varmint
First Name: Vernon
Last Name: Worley
Re: Were these standard on tube stems?
Post by varmint » Mon Feb 18, 2019 3:14 pm
Valve core removal tool?
I don't know if the cores were meant to be removable back then.
Vern (Vieux Carre)
Post by RajoRacer » Mon Feb 18, 2019 3:16 pm
If you are referring to the valve stem remover cap, then no, I don't believe they would have been.
Post by Rich Eagle » Mon Feb 18, 2019 3:25 pm
Here is a discussion that may be interesting in this vain:
http://www.mtfca.com/discus/messages/25 ... 1338838431
Post by DanTreace » Mon Feb 18, 2019 3:32 pm
Yes
Std. equipment with Schrader tube valves, Ford didn't make tires or tubes, got them from the big companies.
Post by Steve Jelf » Tue Feb 19, 2019 12:17 am
Yes, that's one automotive part that hasn't changed in a hundred years.
Roverdriver
First Name: Dane
Last Name: Hawley
* REQUIRED* Type and Year of Model Ts owned: Nil
Post by Roverdriver » Tue Feb 19, 2019 12:40 am
The valve cap with the valve removal tool was definitely standard for Schrader Valve inner tubes right into the 1950's. When the plastic cap was introduced as a replacement, wise motorists started to hoard the brass 'tool end' caps. As that generation finishes with motoring, astute hunters will find, when the old garage is cleared, the odd jar of tool caps that have been hoarded over the decades, and kept ready for use.
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Tue Feb 19, 2019 1:30 am
You only need one valve cap with the core removal tool - the rest can be of the plain variety. If your car has a spare tire, keep the notched cap on the spare.
The metal valve caps sold by Schrader, regardless if they are plain or include the tool, had a rubber gasket. That is "extra insurance" against leaky valve cores.
See this thread:
http://www.mtfca.com/discus/messages/50 ... 1432599771
Post by RajoRacer » Tue Feb 19, 2019 11:56 am
I stand corrected.
Fozz71
Last Name: Chochole
Post by Fozz71 » Tue Feb 19, 2019 8:13 pm
Well I must say that I learned a lot from this thread- Schrader valve core removal tool. Nice!
Thanks fellers!
Post by Original Smith » Wed Feb 20, 2019 9:33 am
It appears the valve stem you have pictured is for a larger car, and are using a rim nut to hold it to the felloe.
Peter, Memphis TN
First Name: Peter
Last Name: Claverie
Post by Peter, Memphis TN » Wed Feb 20, 2019 11:17 am
I've found that the cap with removal tool makes the stem too tall for the big cap. So, I have one only on my spare tire.
By the way, this reminds me of a good little Trivia question - which I got from CarTalk:
There is a part of your car that is exactly the same as it was when it was first made, which was well before there were automobiles. It cost about 15 cents then, and still costs about 15 cents. What is it?
Hint: There are at least 5 of this part on your car, and maybe as many as 7 or 8.
Answer: The Schrader valve. It was in use (on bicycles, etc.) before there were cars. You have 5 tires on your car, including the spare, but there may be 2 or more in the Air Conditioning system.
