Alternator voltage output
Topic author - Posts: 269
- Last Name: Bourgeois
- * REQUIRED* Type and Year of Model Ts owned: 1914, 1926, 1927
I have been getting the T ready for a tour.
The wood is in and waiting for the upholstery.
While waiting, I have turned my attention to the mechanicals.
I made sure it started and ran just like before.
The T is 12 volts, distributor and a Texas T Parts alternator.
While it was running I checked the voltage to the battery.
It was running at 13.6 volts. I was thinking it should be a little over 14 volts.
Even at a higher RPM it still sat at 13.6 volts.
Does this sound like a healthy alternator?
- First Name: Chris
- Last Name: Brancaccio
- * REQUIRED* Type and Year of Model Ts owned: 1909 Roadster 1915 Coupelet 1923 Coupe 1926 Touring
Re: Alternator voltage output
14.4 V is normal but I think you will be fine with 13.6
Maybe give them a call if you are concerned.
Chris
Chris
Chris Brancaccio
MTFCA Webmaster
MTFCA Forum Admin
MTFCA Webmaster
MTFCA Forum Admin
- First Name: Mike
- Last Name: Kossor
At 13.5V the battery will be maintained definately without risk of boiling out the electrolyte or over charging.
- Last Name: Strange
13.6 will be fine.
- First Name: Neil
- Last Name: Kaminar
Steve,
How long has the battery been sitting? With the same current input, as the battery becomes more charged the voltage goes up. The voltage may be due more to the battery than the alternator.
- First Name: Neil
Steve,
You may want to try charging the battery with a battery charger and then try the alternator again. If you have a hydrometer, check the specific gravity of the acid. After charging, let the battery sit overnight and then check the voltage. It should be about 12.4 volts. How old is the battery?
- First Name: Tom
- Last Name: Moorehead
All Texas T alternators I have put out 13.6 volts when new and still do. One is 10 years old. The oldest battery of the 3 is 5 years old.
When was the last time your Voltmeter was calibrated?
