13T - Gas Lamps Coming Back to Life
Darin Hull
First Name: Darin
Last Name: Hull
* REQUIRED* Type and Year of Model Ts owned: 1913 Model T & 1926 Model T project
Board Member Since: 2010
Post by Darin Hull » Fri Oct 09, 2020 8:24 pm
Decided to work toward getting functional lamps since I picked up an acetylene generator at Luray. Was able to get one of the oil lamps immediately started up with a new wick. Attached are the pics. The other oil lamp has a leaking base. So will see if I can seal up the pinholes then get it lit with its new wick.
For the acetylene head lamps, have parts to order and some supplies. So, I will post pics in the future as I make progress. Don’t plan on operating the lamps often... but want to know they are back in working order if the magic needs to happen.
Darin
Drkbp
First Name: Kenneth
Last Name: Parker
Re: 13T - Gas Lamps Coming Back to Life
Post by Drkbp » Fri Oct 09, 2020 11:44 pm
Looking good!
I did the same and got my kerosene lamps working first on my '14.
The three "square" lamps really aid in making you more visible from the side and back
during the low-light times, early and late in the day.
Easily adds an hour of driving time to either end of the day!
Only takes a minute to light them and they can stay lit while parked.
The acetylene lamps are different in that they are air cooled while driving.
Post by Mark Gregush » Sat Oct 10, 2020 1:02 am
Looking good! You might want to turn the flame down some it's too tall and looks like it about to start smoking. The wick should be tight across the top, no fuzzing and cut straight across and maybe an angled snip on each end.
Darin Hull
First Name: Darin
Last Name: Hull
Post by Darin Hull » Sat Oct 10, 2020 9:23 am
Thank you for the advice! I’ll post more pics when I make more progress.
Darin
