Z head
mjr
Topic author - Posts: 7
- First Name: MARSHAL
- Last Name: REYSEN
- * REQUIRED* Type and Year of Model Ts owned: 1925 touring 1926 Dr. coupe
Z head
I want to put a Z head 6 two 1 on my 25 touring it has a 26 motor, what are your thoughts.
- Last Name: Juhl
Re: Z head
I have one on my 1917. Dyno showed almost 22 HP at 1200 rpm and 26 HP at 2000 rpm. I'm very happy with the car's performance.
KenHaverhill
- First Name: Kenneth
- Last Name: LeBlanc
- * REQUIRED* Type and Year of Model Ts owned: 27 coupe 23 touring 26 TT Snowmobile 22 TT Dump Truck 26 Fordoor
Re: Z head
I run a z head on my t's and have been very happy. My best experience was adding one to my tt snowmobile it made a huge power difference on a very heavy machine. I have had no negative issues
KeithG
- First Name: Keith
- Last Name: Gumbinger
Re: Z head
Hi Marshall, There are lots of Z heads in use with good results. I have 2 of them and like them very much.
Keith
Keith
Kerry
- Last Name: van Ekeren
Re: Z head
When fitting a Z head you must check that you have piston clearance, more often than not you need to grind the head some. Power wise they are great.
Re: Z head
I'll second Frank's observations. there are enough differences between Z heads that each should be trial fitted before finally installing. I do this without a gasket first. Hand crank over to check for any knocks. Tap it back as far as it will go on the bolts and repeat. Tap it forward and repeat. On more than one occasion, the combustion chamber had to be relieved a little for the rising piston to clear. Once fitted, hand crank again to be sure.
They do give instant power and represent good bang for the bucks invested.
RGould1910
- Last Name: Gould
Re: Z head
Good advice Allen. Especially if you have large cylinder bores. My 27 is bored .080 OS and I beveled the pistons to achieve clearance on a Ricardo head.
