Oil funnel twisting
tommyleea
First Name: Tommy
Last Name: Russell
Oil funnel twisting
Post by tommyleea » Sun Dec 13, 2020 9:54 am
When removing the magneto ring from the engine, I noticed the oil funnel wanting to twist along with the hold down bolt. I am pretty sure it will try and do the same thing upon installation. Is there a way to prevent the twisting? 23 T..Thanks..Tommy
Adam
First Name: Adam
Last Name: Doleshal
Re: Oil funnel twisting
Post by Adam » Sun Dec 13, 2020 10:02 am
Hold it in place with two fingers of your other hand.
Post by Steve Jelf » Sun Dec 13, 2020 10:28 am
You could also smear on a little grease where the bolt will turn against it.
tommyleea
First Name: Tommy
Last Name: Russell
Post by tommyleea » Sun Dec 13, 2020 10:46 am
Thanks for the responses. I did try to hold it when removing the bolt, but it wouldn't let go. Maybe installing it will work better. I guess it isn't a common problem. The grease sounds like a good idea. Thanks again..Tommy
Sarikatime
Last Name: Seress
Post by Sarikatime » Sun Dec 13, 2020 10:48 am
Put a washer under the nut and the nut will turn with the washer only, a little grease like Steve said will help with it as well. Frank
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Sun Dec 13, 2020 12:41 pm
If you put a washer under the nut, it effectively makes the bolt a little shorter. If you don’t have enough thread engagement, you risk stripping the threads out of the block when you torque the bolt. Be very mindful of that.
tommyleea
First Name: Tommy
Last Name: Russell
Post by tommyleea » Sun Dec 13, 2020 1:06 pm
Just safety wired bolts, no nuts.
