will pancake hasslers bolt to the rear of a big drum ruxtel
Topic author - Posts: 27
- First Name: warwick
- Last Name: preval
- * REQUIRED* Type and Year of Model Ts owned: 25 tr 22 coupe
- Board Member Since: 2014
Hi all will Hassler shocks bolt to a 26/7 big drum Ruxtel with( Rocky mountain brakes) so i can match the front hasslers on my 22 coupe cheers Warwick.
Re: will pancake hasslers bolt to the rear of a big drum ruxtel
The older beehive style will not - shock mount to brake band conflict unless the mount base is "shimmed" out - can't comment on pancake style as I've not mounted any BUT the rear mount is quite different.
- First Name: Tony
- Last Name: Bowker
I remember reading that cannot use Hasslers with the RM brakes because of interference.
If the original Hasslers would not fit the large drum rear end, it seems very likely that they would be redesigned for the 26/7 brake drum. Someone must know......
Tony Bowker
La Mesa, California
La Mesa, California
- First Name: Herman
- Last Name: Kohnke
- * REQUIRED* Type and Year of Model Ts owned: 1914 Roadster, 1922 Coupe
The Pancake style were made especially for the 26-27's.
The fronts will fit all, but the rears only the large drum.
Herm.
Herm.
- First Name: Wilbur
- Last Name: Swearingin
- * REQUIRED* Type and Year of Model Ts owned: 1923 Runabout 1923 Coupe 1924 Tudor 1926 Pickup
i have pancake Hasslers both front and rear on my 1924 Tudor with a Ruckstell rear axel. Just installed the new AC brakes. All fits and works well.
