How much water-soluble oil do you put in a Model T radiator?
NorthSouth
Last Name: California
* REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1926 Pick Up
Post by NorthSouth » Tue Dec 29, 2020 9:15 pm
Hello fellow Model T-ers,
I just had my radiator repaired and flushed. I'm starting anew. I ordered a quart of water-soluble oil from Amazon. Can any of you tell me how much of it I need to put in my refreshed Model T radiator along with the garden hose water?
Thank you in advance.
Steven
Last Name: Humble
Board Member Since: 2006
Re: How much water-soluble oil do you put in a Model T radiator?
Post by Humblej » Tue Dec 29, 2020 9:24 pm
Use green antifreeze 50/50 mix with distilled water and throw away the water sol oil whatever that is. Avoid tap water as that has all the minerals that clogged up your radiator in the first place.
Harry Lillo
First Name: Harry
Last Name: Lillo
Post by Harry Lillo » Tue Dec 29, 2020 11:06 pm
Someone with more experience may have better information. I really couldn't find much information on mixing ratios when I started using the soluble oil/water blend in my T's. I have used it for five driving seasons.
I use about 3/4 to 1 cup in each engine.
It gives an ugly chocolate brown mixture when it boils over.
I drain it at the end of each driving season.
Some of my T's have an antifreeze mix and that works well.
Harry Lillo
Post by TRDxB2 » Wed Dec 30, 2020 12:52 am
From the Internet https://natrad.com.au/info-advice/can-p ... -radiator/
"Ideally, this would be distilled water. You can also use bottled water or tap water. Bear in mind that tap water or bore water contains minerals that can leave deposits throughout your cooling system, contributing to corrosion and reducing the lifespan of the radiator"
I have been unable to find any information on what ratios of soluble-oil to water are able to reduce the temperature/boiling point of water. There were many responses in MTFCA past posts of what members used but nothing relating to the product they were using.
Automotive Water Pump Lube products are contain water-soluble-oils as does Redline's Wetter Water. Their claim is it reduces water temperature "UP TO" 20 F. So if you get 1 degree reduction it worked. As noted in many previous posts water-soluble-oil is not an anti-freeze.
Post by Steve Jelf » Wed Dec 30, 2020 2:16 am
I use 50/50 antifreeze/water. It prevents freezing and it prevents corrosion. Do NOT use tap water. It's full of minerals. It won't hurt you, but it will make your cooling system sick. Distilled water is only 88¢ a gallon at Walmart. Use it. Will something else cool better than antifreeze? Maybe. Do you NEED something to cool better than antifreeze? No.
Tim Rogers
Last Name: Rogers
Post by Tim Rogers » Wed Dec 30, 2020 7:51 am
None......
got10carz
Last Name: Meixner
* REQUIRED* Type and Year of Model Ts owned: 1911,13,14,19,23,25,26,27
Post by got10carz » Wed Dec 30, 2020 8:38 am
If you are buying the stuff made for machine shops, I would say a cup. The old water pump lube was soluble oil, was probably pint sized, install the whole container. The new water pump lube I'm not convinced is soluble oil, as it doesn't turn white when diluted in water, but it says it is rust inhibitor.
Rich Bingham
First Name: Rich
Last Name: Bingham
Post by Rich Bingham » Wed Dec 30, 2020 10:20 am
I use one pint.
Remember, all opinions are absolutes, so be sure to follow all forum recommendations to the letter ! :lol:
"Get a horse !"
Post by Jerry VanOoteghem » Wed Dec 30, 2020 11:44 am
I only use water from melted Antarctic glaciers. Anything else will cause your Model T to explode. :)
Seriously though, I know some parts of the country have water with high mineral content that can really screw things up. However, I think that in most large metropolitan areas, (Flint, MI excluded), tap water will do just fine. It's all I've ever used. But then Metro Detroit, (Flint, MI excluded), has some of the nation's best water, (thank you Great Lakes!).
Post by Norman Kling » Wed Dec 30, 2020 11:58 am
I don't know much about water soluble oil, however, the California tap water will plug your radiator. I use green antifreeze, one gallon and enough bottled "purified" or distilled water to top off. If I need to add, I use the "purified " water. The anti freeze also has rust inhibitor in it. Of course, I live where it rarely freezes and if it does, the lowest it has gotten in the 46 years I have lived here was 18 above, only once. usually only a few nights per year does it bet below freezing. So use the mix of anti-freeze recommended for your area. Our well water has so many minerals that when we have gotten a small drip after I work on the pluming and can't seem to get it to stop, I can put a bucket under it and after a few weeks the drip stops because the water is like stop leak. But it will continue to build up until it stops a radiator, so don't use tap water. Now I have heard that if you have extremely soft water in your area, it might be OK to use. The only experience I have had with soft water is when I take a trip, to a soft water area, if I take a shower, I feel as if I can't rinse off all the soap.
Post by Steve Jelf » Wed Dec 30, 2020 12:09 pm
I boil tap water for my morning tea in this pan. I haven't de-mineralized it for a couple of weeks. This is why I use distilled water in my vehicles. As Jerry says, mineral content varies all over the country. If I'm traveling I don't know what's in the local water, so I use distilled water when I'm on the road too.
Dave S
First Name: David
Last Name: Simmering
* REQUIRED* Type and Year of Model Ts owned: 1911 Touring, 1925 Coupe, 1926 Roadster Pickup
Post by Dave S » Wed Dec 30, 2020 1:06 pm
For many years, I have put Prestone Anti Rust in the radiator of our '11. It's drained each fall. I feel that straight water is not good for a T motor. I also think that anti-freeze can find its way in places where it shouldn't. It is engine 55988 and I try to take good care of it.
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Wed Dec 30, 2020 1:32 pm
Prior thread regarding the same subject:
http://www.mtfca.com/discus/messages/82 ... 1526784320
NorthSouth
Post by NorthSouth » Wed Dec 30, 2020 3:00 pm
Thank you everyone. This was excellent information. I will be following the distilled water recommendation with 1-1/2 cups of Stay-Lube soluble oil added to the full radiator.
HAPPY NEW YEAR !!!
Steven
Mighty1924
First Name: Rick
Last Name: Shaw
* REQUIRED* Type and Year of Model Ts owned: 1922 Touring. 1924 Coupe
Post by Mighty1924 » Wed Dec 30, 2020 4:21 pm
For those who only use water here is a link to a rust/corrosion inhibitor product and radiator flush.
https://www.no-rosion.com/hyperkuhlcoolant.htm
I found out about these products through the
Model A Restorers Club
No-Rosion Cooling System Corrosion Inhibitor
No-Rosion Industrial Grade Cooling System Flush.
Rick S
Post by Mark Gregush » Wed Dec 30, 2020 6:16 pm
All that water soluble oil is going to coat the walls/inside of the radiator and cut down on thermal transfer. If you are trying to protect against rust and corrosion, go buy one of the product made for that. There are plenty to chose from on the shelf at most auto parts stores.
