Happy New Year! What are you planning to do on your Ts this year?
				Jonah D'Avella
Topic author - Posts: 700
 - First Name: Jonah
 - Last Name: D'Avella
Happy New Year! What are y'all planning to do on your Model Ts in this new year? I am planning to reupholster and paint mine!
					Last edited by Jonah D'Avella on Fri Jan 01, 2021 9:22 am, edited 1 time in total.
				DJPeterson
 - First Name: Dale
 - Last Name: Peterson
 - * REQUIRED* Type and Year of Model Ts owned: 1915 Touring, 1916 Roadster, 1925 Roadster PU, 1926 Canadian Fordor, 1927 Speedster
Re: Happy (almost) New Year! What are you planning to do on your Ts this year?
Was planning to replace the axles in the Ruckstel due to bad threads.  On tear down found one frozen and broken differential pin and wrecked inner differential body and plate.  Damage rang up at $403 from Chaffin's but held up by holiday delay in parts machining.
Also planned a freshen up of the engine but looks like more serious rebuild due to cracked exhaust port and scored cylinder from seized piston 30,000 miles back.
This early 1916 is still my favorite of the 5 in the stable, so worth the time and expense.
david_dewey
 - Last Name: Dewey
I plan on replacing the wood in Barney's body. That's the big major project. Of course, while the body is off the frame, I will likely go through the mechanicals too, but the big push is to do the body wood. Since it's a '25 there is a bit less wood to do than the earlier models!
									T'ake care,
David Dewey
						David Dewey
dr1960
 - Last Name: Ruedy
 - * REQUIRED* Type and Year of Model Ts owned: 1915 Model T Runabout Pickup
Planning to get my 1915 Runabout back on the road with a freshly rebuilt engine by Mike Bender!
									David - Yukon, OK
1915 Runabout: Finish rebuilding coil ring; reinstall mag/transmission; reinstall engine & get the car running; make rivets, reassemble, & install new windshield; sew up floppy top; install turn signals/tail lights; stop rear axle leak; repaint bad spots; install a real 1915 speedometer; other minor odds & ends.
1923 Touring: Clean out band fuzz & debris; rebuild transmission with new low drum; replace ruined flywheel; reinstall engine/transmission and get the car running; assemble & install a Ruckstell; install AC brakes; finish top irons & bows, install new top; move speedometer sensor into a rear brake drum; other minor odds & ends.
				TBill
 - First Name: Bill
 - Last Name: Obier
 - * REQUIRED* Type and Year of Model Ts owned: 1926 Fordor, 1926 TT, 1913 Speedster (WIP)
I’m hoping to complete my 1926 Fordor restoration in time for 2021 Cruisin the Coast in Biloxi this October.
Also trying to restart the Louisiana Lizzies chapter of MTFCA.
				StanHowe
 - First Name: Stan
 - Last Name: Howe
Re: Happy New Year! What are you planning to do on your Ts this year?
Switch the vaporizer to a NOS Cyclone carb, install the heater, Ruckstell and sure stop brakes, remove the panel below the trunk lid and build a wooden pickup box to fit in there, redo all the wiring, put a top on and go drive it.
Same list as last year - never had it started this past year, never put a wrench on it.
				John Codman
 - Last Name: Codman
Get at least one wheel restored on my '27. Two are done - two to go.
 - Last Name: House
Trailer my centerdoor to Rockport to tour environs with the San Antonio club in February. Then trailer my roadster to Lebanon MO for the ‘Show Me’ tour
 - Last Name: Hjortnaes
1. Paint the two wheels Stutzman is sending me
2. Speedster Reunion in Nebraska.
3. New London to New Brighton Run in MN.
4. Old Car Village in Detroit.
5. Drink a cold beer.
				John Dow
 - Last Name: Dow
In May (hopefully) when I get the engine back after total rebuild, I plan to install it in my '23 Touring.  Before then I will mount the 4 new tires I received 3 weeks ago.
varmint
 - First Name: Vernon
 - Last Name: Worley
Lord willing, too much to post here.  Hopefully, get the body on the frame for the first time we have ever seen.  Hopefully, hear the engine run for the first time.  Hopefully, make all the interior fabric stuff.  Hopefully, replace all the wood fragments with whole pieces.
									Vern (Vieux Carre)
				Ralph F
 - First Name: Ralph
 - Last Name: Fitz-Gerald
Looking to clean up the undersides of my fender. Just wondering what would be a good product to use. I drive on a lot of dirt roads. I am also looking at replace the gas tank also, notice it is starting to weep.
Fitz
						Fitz
Duey_C
 - First Name: Duane
 - Last Name: Cooley
Get the '18 PsychOdelic Runabout out of storage, home and drive it again.
Wake the Crappy '24.
Ruxstel24
 - Last Name: Hanlon
I'm late for the party again...
But I wish everyone a Happy New Year !!
I plan to pull my steering column and try to tighten the rivets in the gear to tube and replace the bushing in the frame bracket.
Get ether the 1925 cut down T or 1920 Dodge touring ready in case we have tours this year!! The 1925 needs body wood(started cutting templates but band saw blade broke), engine overhaul, rear end checked out and upholstery. The Dodge needs upholstery, tires, 2 more disk wheels and hubs for rear, different rear end and general maintenance work. When it comes to upholstery, lets just say nether are getting original style installed at this point. I will be happy with springs and something covering same.
 Don't know how far I will get, but may end up having to barrow a T if we have any tours.
