Chickasha almost ready
D.Yoder
- First Name: DEAN
- Last Name: YODER
- * REQUIRED* Type and Year of Model Ts owned: 19tour,24tour,25rdpu,27rd.26coupe,TT's,& tractor conversions
Heater installed almost ready to head south.
Rob
- First Name: Rob
- Last Name: Heyen
Re: Chickasha almost ready
Brrrrrrrr......
John Warren
- Last Name: Warren
That's a cute little stove. Is it something that you put together?  What does it use for fuel?   Looks like you could cook on it  too. Thanks
FreighTer Jim
- Last Name: Jarzabek
- Board Member Since: 2008
			Like Dean - the stove runs on “ True Grit “ .....
FJ
 FJ
Google “ Model T Transport “
MTFCA - MTFCI - MAFCA Member
				MWalker
- First Name: Mike
- Last Name: Walker
Dean -- The weather here (just east of Chickasha) will be cold this next week, but in the 60's by the weekend.  Chances are it will be OK by the time the swap meet rolls around.
				Jim Derocher
- First Name: Jim
- Last Name: Derocher
- * REQUIRED* Type and Year of Model Ts owned: 1919 Station Wagon
That stove looks a lot like one my neighbor had in his garage. The one he had used wood and was used in a caboose for heat and warming chow. Looks great!  JD
Tim Rogers
- Last Name: Rogers
- Board Member Since: 2013
			Very awesome, but please have a CO2 detector onboard.
I believe that would be CO (carbon monoxide)....have a CO2 detector onboard.
Duey_C
- First Name: Duane
- Last Name: Cooley
That's really neat! Looks right at home!
RustyFords
- First Name: Don
- Last Name: Allen
Maybe a CO2 detector to make sure you're still alive.Steve Jelf wrote: ↑Sun Mar 03, 2019 11:44 amI believe that would be CO (carbon monoxide)....have a CO2 detector onboard.
1924 Touring
FreighTer Jim
			I have had a loft at the front of my last (2) enclosed trailers.
Sometimes I have had to sleep up there in sub zero temperatures.
Rather than heat the surrounding area - I layer sleeping bags over me
and take a large sturdy plastic tote & turn it on it’s side - put my pillow
in it and then drape a blanket over it.
With some adjustment you have the perfect blend of fresh air and ventilation
to exchange the carbon dioxide you breathe out with the air you breathe in.
Your body is a great little furnace that generates sufficient heat to provide
adequate warmth to keep you quite comfortable if you insulate it correctly.
Headaches you may get while sleeping in the cold are usually caused by
inhaling the carbon dioxide you exhale out during respiration.
FJ
FJ
