OT: How to drill a neat hole in an enameled pail?
Chris Bamford
First Name: Chris
Last Name: Bamford
* REQUIRED* Type and Year of Model Ts owned: 1924 Speedster 1926 Touring
Post by Chris Bamford » Mon Mar 04, 2019 6:43 pm
I need to drill two holes in this pail. One about 1" diameter in the bottom, and a second one about 1/2" diameter near the top.
I expect this coating will want to crack and/or chip — any suggestions for doing a neat job on this?
Angmar
Last Name: Bailey
Re: OT: How to drill a neat hole in an enameled pail?
Post by Angmar » Mon Mar 04, 2019 7:02 pm
I have used porcelain bits in the past, starting small and going up. Easy does it kind of thing.
Still crankin old iron
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Mon Mar 04, 2019 7:21 pm
Using a small grinding stone in the area to be drilled down to bare metal is the key. Take your time and she will come out great.
All the Best,
Hank in Tin-A-See
Rich Bingham
First Name: Rich
Last Name: Bingham
Post by Rich Bingham » Mon Mar 04, 2019 7:47 pm
Just nosey . . . why do you want to drill holes in that pail ? Enamelled steel articles aren't easy to come by. Would something else do ?
"Get a horse !"
CraneJon
First Name: jon
Last Name: crane
* REQUIRED* Type and Year of Model Ts owned: 1925 T pickup, 1928 A, 1931 A
Post by CraneJon » Mon Mar 04, 2019 9:07 pm
Makin a still?
ModelT46
First Name: Darel
Last Name: Leipold
Post by ModelT46 » Mon Mar 04, 2019 9:17 pm
I use a diamond coated glass drill bit.You will want to run cooling water when using a glass drill bit.
Chris Bamford
First Name: Chris
Last Name: Bamford
Post by Chris Bamford » Tue Mar 05, 2019 9:58 am
Thanks all for your comments. I'm going to start with Henry's suggestion.
HI Rich — I need the look of porcelain and an intact inside coating for this project. I'll post some photos when complete (a month or two).
This pail is indeed in nice shape but may not be as old as it appears. The material is fairly light and the label has a newer look to it. A bit of online poking around suggests this piece dates back to the '50s. I combed a couple of antique malls yesterday looking for this sort of thing and was surprised how much enamelware is still around.
HPetrino
First Name: Henry
Last Name: Petrino
Post by HPetrino » Tue Mar 05, 2019 10:09 am
I'd use a diamond coated bit as Daryl suggests. I've used them on similar things recently and they work well. Just keep a spray bottle of water handy and cool it regularly.
Post by Scott_Conger » Tue Mar 05, 2019 10:13 am
Still a shame to drill a hole into something so nice that a collector would likely display...label and all.
Tmodelt
First Name: Kim
Last Name: Wynn
* REQUIRED* Type and Year of Model Ts owned: 1923 Roadster & 1927 Speedster
Post by Tmodelt » Tue Mar 05, 2019 10:33 am
I am not endorsing any store or product, but Lowe's sells a rattle can of paint that resembles the blue enamel campware. I haven't used it yet but plan on picking up a can to tryout the next time that I pass one of their stores.
