1925 Model T Ford scale model running
Dan Haynes
Last Name: Haynes
Post by Dan Haynes » Sat Feb 20, 2021 4:30 pm
Kerry
Last Name: van Ekeren
Re: 1925 Model T Ford scale model running
Post by Kerry » Sat Feb 20, 2021 4:39 pm
I think it's BS, no way carburetor jets and fuel line that small work, just look at what is required to run a model plane and car engines.
John Codman
Last Name: Codman
Post by John Codman » Sat Feb 20, 2021 5:37 pm
I'm not so sure. I have seen models of V8 engines that small that actually did run. It's amazing that some folks have the skills to do this.
Post by Rich Eagle » Sat Feb 20, 2021 5:59 pm
Post by Jerry VanOoteghem » Sat Feb 20, 2021 7:15 pm
I've seen this scale model Duesenberg in person & running. If this guy can make a running Duesy on this scale, then a Model T should be a cinch. Every last detail of this Duesenberg is complete & accurate, right down to working hydraulic shock absorbers.
https://www.youtube.com/watch?v=f6TetkMpFIc
Pep C Strebeck
First Name: Joseph
Last Name: M
Post by Pep C Strebeck » Sat Feb 20, 2021 7:22 pm
He says in the comments for the video;
"Hola la maqueta tiene un motor a pilas que simula el sonido del motor."
This would translate to;
"Hello, the model has a battery-powered motor that simulates the sound of the motor."
A great and very detailed model, but not a gas engine.
Post by Jerry VanOoteghem » Sat Feb 20, 2021 7:29 pm
Wow. Thanks! He had me completely fooled, (not that he was trying to, just that I no hablo espanol).
I was most impressed by the low speed idle. Very difficult to do in a scale model engine, but not so hard when using an electric motor I guess.
Last edited by Jerry VanOoteghem on Sun Feb 21, 2021 3:00 pm, edited 1 time in total.
Last Name: Wrenn
Post by TWrenn » Sat Feb 20, 2021 7:33 pm
Regardless, it's pretty darned COOL!!
desertexplorer
First Name: Wallace
Last Name: Bellows
* REQUIRED* Type and Year of Model Ts owned: To Many!
Post by desertexplorer » Sat Feb 20, 2021 7:43 pm
Here is a link to the guys web site showing a little more detail.
https://rubenvinyolas.com/ford-model-t- ... k-up-1924/
