LED Bulb replacement for acetylene headlights
				bdtutton
Topic author - Posts: 225
 - First Name: Bryan
 - Last Name: Tutton
 - * REQUIRED* Type and Year of Model Ts owned: 1914 Model T
I would like to convert my acetylene headlights on my Model T to LED headlights.  I found some nice halogen bulbs that mount directly onto your burner base at Langs. https://www.modeltford.com/item/BL-H.aspx   Unfortunately, I don't have enough power to drive the halogen lights so I am looking for the equivalent option that uses LED bulbs.  Several people have commented about LED replacement bulbs for gas headlights, but I can not find them.  Does anyone know where I can buy some???
				dmdeaton
 - First Name: Danny
 - Last Name: Deaton
Re: LED Bulb replacement for acetylene headlights
Someone will chime in as I cannot remember who. Someone on here was making them
				Dan Haynes
 - Last Name: Haynes
"The further a society drifts from truth, the more it will hate those who speak it."  -George Orwell
PDGx
 - First Name: Paul
 - Last Name: Grohsmeyer
I’m using these from Snyder’s  on my Mack.
PN: T-6602-LED
https://mtfca.com/phpBB3/viewtopic.php? ... 69#p136869
They are pretty decent, but 12v not 6.
									PN: T-6602-LED
If my short term memory gets any shorter, I won’t even have thought about what I’m going to forget.
17 TT Holmes Wrecker
22 Mack AC Tiltbed Wkr
30 A Rdstr PU
58 Mack B-61 Semi Tractor / 85 Roger’s RGN
08 Philbilt Stepdeck Semi
30 A Rdstr PU
PDGx
 - First Name: Paul
For what it’s worth -
Had one of these laying around and never used it on the T,
but thought I’d try to fire up one of these led conversion bulbs. 6v would not pass the start test, but these have no problem lighting them up.
Don’t know how much each lamp draws, but 3a might handle 2 if you must stay with a 6v system.
thom
 - First Name: Tommy
 - Last Name: Coffey
Seems like such a shame to do the conversion, but I guess I understand wanting brighter lights.
Novice
 - First Name: Jim
 - Last Name: Davis
How many lumens does a period model T acetylene headlight put out.
				bdtutton
 - First Name: Bryan
 - Last Name: Tutton
I contacted Snyders today and they have T-6602-LED in stock....so I ordered some.  I will be running a 12 volt system so these should work well.  When I get the new LED lights I will run some tests and report my results.
 - First Name: Keith
 - Last Name: Townsend
Jim-
It depends on what size of burners you are using. They are rated in cubic feet of gas burned per hour.
Standard burners used on the Model T were .75
1 candlepower = 12.57 lumens
.50 burners put out 18 candlepower x 12.57 = 226 lumens
.75 burners put out 29 candlepower x 12.57 = 365 lumens
1.0 burners put out 45.6 candlepower x 12.57 = 572 lumens
How many lumens do those LED "burners" put out?
Just remember, if you electrify you acetylene lamps, you will looks a couple of points on the "cool factor".
-Keith
-Keith
