Clamps!
ivaldes1
First Name: Ignacio
Last Name: Valdes
Clamps!
Post by ivaldes1 » Sun May 23, 2021 2:28 pm
Clamps! I nearly ran out.
As discussed previously I went with Titebond III viewtopic.php?f=2&t=20040&p=152776&hilit=glue#p152776 but may have to go back with epoxy for 2 larger than expected joint gaps or maybe just build it up with Titebond III.
ModelTWoods
First Name: Terry
Last Name: Woods
Re: Clamps!
Post by ModelTWoods » Sun May 23, 2021 4:31 pm
Ignacio, Reminds me of the old steering wheel spinner knobs that people used to attach to their steering wheels, except yours aren't spaced out around the wheel. You should have plenty to grab a hold of to turn your wheels, if they don't beat your chest or stomach to death when turning it. :lol: :lol: :lol:
Petrah Phyre
First Name: Sean
Last Name: Pownall
* REQUIRED* Type and Year of Model Ts owned: 1926 Speedster
Re: Clamps!
Post by Petrah Phyre » Sun May 23, 2021 5:26 pm
I've seen this type of repair done by wrapping an old inner tube (stretched tite) around the glue joint. Might make some sense to wrap it with cling wrap first to make removal easier.
First Name: Keith
Last Name: Townsend
Re: Clamps!
Post by KWTownsend » Sun May 23, 2021 10:31 pm
Ratchet straps help, too...
ivaldes1
First Name: Ignacio
Last Name: Valdes
Re: Clamps!
Post by ivaldes1 » Wed May 26, 2021 11:04 pm
It is coming along. I have it mostly sanded better than what the pictures show. The worst was duct tape residue that had soaked in. I am probably going to do cherry stain but is yellow done with honey oak stain or no stain? https://duckduckgo.com/?q=model+t+ford+ ... &ia=images
Last Name: Tannehill
Re: Clamps!
Post by JTT3 » Wed May 26, 2021 11:06 pm
Looking good Ignacio, keep it going.
ivaldes1
First Name: Ignacio
Last Name: Valdes
Re: Clamps!
Post by ivaldes1 » Fri May 28, 2021 3:12 pm
One of the joints was loose and clicking but not wide enough to use the bottle to put Titebond III in. Further separation would cause damage. Solution: Syringe with a 30 gauge needle. Worked perfect.
ivaldes1
First Name: Ignacio
Last Name: Valdes
Re: Clamps!
Post by ivaldes1 » Fri Jun 04, 2021 5:13 pm
Stained but not clear coated yet.
