Can anyone explain to me what the purpose is of the 5021 PS spring on the Bendix starter assembly? What does it do? What is the best way to install it?
What cautions are there regarding it's installation?
This is the tiny spring that installs crosswise in the 5021G gear cup, that spins on the Bendix assembly. It is visible on the Vowell Art drawing of the Bendix assembly.
Thanks very much!
Purpose of Tiny Spring on Bendix (5021PS)
Re: Purpose of Tiny Spring on Bendix (5021PS)
the pin/spring keeps the bendix from vibrating forward & hitting ring gear when running. Very important. It rests in that undercut back area. The pin rides on TOP of one of the threads. If they were together initially the will go back correctly. To install, the nose bearing has to be unscrewed. Undo The 2 pricks locking it. Pin punch thru the 2 holes. Unscrew it (Hard part) by gripping without damaging it. I have a special 2 piece block to lock on to it & unscrew the bendix body.
Topic author - Posts: 657
- First Name: William
- Last Name: May
Thanks very much!
Three tips Bill.
To remove the endpiece I use two self tapping screws cut off just under the head, leaving the stem about as long as the holes in the end piece are deep. These are inserted in the holes in the side and the endpiece held in a vice, not on the screw heads, with soft alloy jaws. With the bendix spring bolt in place, I use a crescent wrench to turn the drive piece. The screw heads keep the endpiece from turning as they engage against the alloy vice jaws. I have not found it necessary to do any work on the upsets which hold the piece in place. They will be over-ridden as the piece winds off.
Be very careful fitting the pin/spring. The pin is spring loaded, and can fly anywhere if you are not spot on as you install it.
I kiss the back end of the endpiece on my linisher belt before re-fitting it. That allows it to butt up in a slightly different position on the drive piece, and this gives you a fresh spot to punch on to retain it. A dab of loctite is insurance.
Hope this helps.
Hope this helps.
