Testing a Rebuilt Metal Coil Box
1912touring
First Name: Michael
Last Name: Hanson
* REQUIRED* Type and Year of Model Ts owned: 1910 Touring, 1912 Touring
Board Member Since: 2011
Post by 1912touring » Mon Jun 28, 2021 12:39 pm
Good afternoon everyone.
I finished building a new metal coil box and switch this weekend for a 1916 engine. Is there a way to test the functionality of the coil box apart from installing it in a car?
I have verified the coils on ECCT. I want to make sure that the new reproduction switch and my soldering/wiring are good to go.
Kind regards,
Mike Hanson
Kingwood, Texas
George Mills
Last Name: Mills
Re: Testing a Rebuilt Metal Coil Box
Post by George Mills » Mon Jun 28, 2021 1:00 pm
Take the front switch plate off...
use a continuity tester (cheap voltmeter from the parts store set to high ohms)
Remove coils...
One lead on the bottom copper strip...
Other lead on one side of the contact arc bar in the switch housing...
Flip switch....it should cycle the needle to full or zero with each flip...
Move to other side contact bar arc....
Flip switch....same expectation...
Button it all up, should be good to go...
Be careful taking the front plate off the switch, the rotor wants to fall out :)
1912touring
First Name: Michael
Last Name: Hanson
Post by 1912touring » Mon Jun 28, 2021 1:20 pm
Thank you George!
Post by Scott_Conger » Mon Jun 28, 2021 2:05 pm
You should also ensure isolation of the Mag post from the Bat post at all times in all switch positions
George's test will make sure something will work
this test will ensure you don't inadvertently kill your magneto
assuming you used care in the rebuild, this test is unlikely to fail, but if there is a problem, rectifying things would take a good bit of effort. Might just as well go the extra mile and check while it's painless.
George Mills
Last Name: Mills
Post by George Mills » Mon Jun 28, 2021 4:41 pm
Good point Scott!
