Teflon Tape
Teflon Tape
Post by Original Smith » Mon Aug 16, 2021 11:20 am
I have used the yellow teflon tape on two of my cars. I wouldn't recommend using this, as it had failed after one to two years of service.
What I have found to take it's place is Gasoila. It is a thick liquid that is applied with a brush. I'm anxious to see how it works out.
Last Name: Wrenn
Re: Teflon Tape
Post by TWrenn » Mon Aug 16, 2021 11:34 am
If you're referring to attachments to the carb or sediment bulb, i have had great luck using Loctite 567.
Craig Leach
First Name: craig
Last Name: leach
Re: Teflon Tape
Post by Craig Leach » Mon Aug 16, 2021 12:31 pm
Gasoila is a great product. Some times hard to find over the counter. It is used in fire apparatus a lot. The red hard set should not be used on anything you may want to take apart someday as it may not give up with out a fight. Once Gasoila sets up its more resistant to vibration that the teflon based sealants and some part MFG's do not want teflon used on tapered pipe threads because the luberacating effect makes it easy to over torque and damage castings. In a pinch plastic garbage & grocery bags will substitute for teflon tape to get you home.
Craig.
Hudson29
First Name: Paul
Last Name: O'Neil
Re: Teflon Tape
Post by Hudson29 » Mon Aug 16, 2021 2:50 pm
There looks to be a number of Gasoila products. Which one is for Model T use?
Paul
Re: Teflon Tape
Post by DanTreace » Mon Aug 16, 2021 2:57 pm
Tapered pipe threaded gasoline line connections on my Ts, (other than the pack nuts, these need to be easily removable), are best served by good 'ole Permatex #2 gasket sealant.
Spread on the threads and fasten the fitting, dries to a firm setting and is resistant to today's ethanol gasoline too.
Was around at the time of the Model T and still works wonders.
Craig Leach
First Name: craig
Last Name: leach
Re: Teflon Tape
Post by Craig Leach » Mon Aug 16, 2021 4:58 pm
Gasoila has a online apllication chart chart. For the most part they would use them on threads the same as permatex, grey where you use non hardening and red where you use hardening. I have never seen it used on gaskets.
Craig.
Pat Branigan Wisc
Last Name: Branigan
* REQUIRED* Type and Year of Model Ts owned: 1909 two1910,1911, 1913 Tourings
Re: Teflon Tape
Post by Pat Branigan Wisc » Mon Aug 16, 2021 9:20 pm
EZ turn aviation fuel lube works well. It's great on petcocks on the tapered seats. A bar of soap will work to seal a gas leak but I feel more confident in the fuel lube. Works well on some gaskets as well and they can be used over.
Jeff Hood
First Name: Jeff
Last Name: Hood
* REQUIRED* Type and Year of Model Ts owned: 1915 Touring, 1923 Fordor, 1924 Martin Parry Canopy Express, 1925 Coupe
Re: Teflon Tape
Post by Jeff Hood » Tue Aug 17, 2021 5:14 pm
Yellow teflon tape is for use on gaseous lines and fittings. Natural gas, propane, butane, etc. It is color coded yellow like other gas fittings, flex lines, and special PVC gas pipe and sold in plumbing sections of Hardware stores, not Automotive stores. It's not for gasoline!
Alan Long
First Name: Alan
Last Name: Long
Re: Teflon Tape
Post by Alan Long » Wed Aug 18, 2021 7:10 am
I agree with Jeff, the yellow tape is for gas applications. (when I say gas, I’m not referring to Petrol!)
Alan in Western Australia
