26/7 touring Windshield frame question
Topic author - Posts: 1158
- First Name: Robert
- Last Name: Govoni
So I'm going to start putting the windshield together soon and I was looking at a car as a model. Take a look at the rubber gasket in a grove on the bottom of the frame.
Now take a look at my frame. There is no grove in the frame. Did the nickel ones not have it?
Re: 26/7 touring Windshield frame question
I would think all the original ones had the groove. You may have a repro there.
- Last Name: Govoni
Could be but I'm not sure how to tell.
- First Name: Will
- Last Name: Brown
- * REQUIRED* Type and Year of Model Ts owned: 26 Runabout
I didn't know that Ford had nickel windshield frames in 26-27. Maybe an aftermarket one?
- First Name: Chuck
- Last Name: Regan
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster Pickup
My ‘26 has a groove with a small hole to start the rubber seal. Have not seen original windshield frame with plating.
I have a 26 Roadster and a 26 Touring. The Roadster does not have the groove. It has the windshield it came with when I bought it. The Touring has a frame I bought as a repro from Chafin's. It does have the groove. Anyway, I don't know whether any of the originals came without the groove.
- Last Name: Clements
My 26 Roadster has it.
- First Name: David
- Last Name: Wilson
- * REQUIRED* Type and Year of Model Ts owned: 1927 Canadian Touring
My 27 Touring has the original frame with the groove.
The plating looks more like chrome than nickel to me. I don't think Model Ts ever had any chrome plated items on them.
- Last Name: Nunn
Speedway Motors sells a '26-27 windshield frame in chrome. It doesn't appear to have the groove.
- Last Name: Govoni
I betting it's a reproduction. Yes it's chrome along with the windshield side supports and hardware. Could be for making a speedster. Thanks for all the info.
It would be just fine for a topless speedster.
The posts would also have channels to hold the seals on the sides. https://www.modeltford.com/item/7840B.aspx
- Last Name: Codman
My '27 touring car has the groove. I too don't remember ever seeing a T with a plated windshield frame. I also agree that the frame in question looks more like chrome then nickel.
- Last Name: Govoni
So I was looking at the Lang's catalog and saw that the frames and Side supports are not chrome but the wing nuts and other parts are. Someone must have chromed my Side Supports and frame.
