Well, this explains the weird noise…
Chris Bamford
First Name: Chris
Last Name: Bamford
* REQUIRED* Type and Year of Model Ts owned: 1924 Speedster 1926 Touring
Post by Chris Bamford » Fri Oct 01, 2021 11:31 am
Less than a mile from the end of a 560 mile weekend, I heard a ‘ringing’ sound from the engine room, possibly right front. It was reminiscent of the sound of a wet fingertip circling the rim of a wine glass. Not real loud but plenty disturbing.
Turns out I could hardly have asked for an easier outcome — I have a serviceable armature on the shelf and we should be generating again soon after a good cleaning and adjustment.
Strangely, the armature and stub both spun freely in the housing; I have no idea what prompted the shaft to snap as it did.
Re: Well, this explains the weird noise…
Post by speedytinc » Fri Oct 01, 2021 12:05 pm
Another "never seen this before"
Post by Rich Eagle » Fri Oct 01, 2021 12:41 pm
I agree. I've never heard or seen that. I can't imagine why it would break cleanly like that.
Model T's typically do strange, unusual things don't they?
kmatt2
First Name: Kevin
Last Name: Matthiesen
Post by kmatt2 » Fri Oct 01, 2021 1:10 pm
The failure at the front generator bearing could have been caused by a slight misalignment between the front generator bracket and the front mounting bracket, or between the generator main body and front mount, over a long time.
david_dewey
First Name: David
Last Name: Dewey
Post by david_dewey » Fri Oct 01, 2021 5:04 pm
and helped along with the undercut for the bearing. I'd say you were very lucky, as if it had broken on the other side of the bearing the gear would have made a mess in the engine!
T'ake care,
David Dewey
FundyTides
First Name: David
Last Name: Wilson
* REQUIRED* Type and Year of Model Ts owned: 1927 Canadian Touring
Post by FundyTides » Fri Oct 01, 2021 8:24 pm
Like the old farmer said when his horse died "I don't understand it. He never did that before".
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Fri Oct 01, 2021 9:00 pm
Slightly bent shaft that was crashing against the large timing gear and flexing slightly until it work hardened, crystalized and broke.
Dennis_Brown
Last Name: Brown
* REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
Post by Dennis_Brown » Fri Oct 01, 2021 9:52 pm
Now repair the old armature, find a bad armature, press out both shafts and press in the replacement. I have never done it but it can be done.
