Look normal?
JBog
First Name: Jason
Last Name: Bogstie
Look normal?
Post by JBog » Sun Oct 10, 2021 6:37 pm
Cleaned up the engine to get ready for my Z head. Does everything look okay? I've never had my engine's head off before. Looks like some overhauled the engine at least before I got it.
Re: Look normal?
Post by Jerry VanOoteghem » Sun Oct 10, 2021 7:20 pm
Looks like new pistons in old bores. By "old bores", I mean they do not look freshly honed as you would expect to see with new pistons. Do they look like new because you cleaned them up so well, or did they look like this when you removed the head? Have you ever run this engine?
Mark Chaffin
Last Name: Chaffin
Re: Look normal?
Post by Mark Chaffin » Sun Oct 10, 2021 7:41 pm
Looks pretty good. Don't forget to clean out all the head bolt holes with a bottoming tap and air real good before assembly. :)
JBog
First Name: Jason
Last Name: Bogstie
Re: Look normal?
Post by JBog » Sun Oct 10, 2021 8:05 pm
Yea, I've ran this engine as long as I've had the T, about 7 months. Here's some pics of what it looked like when I took the head off.
JBog
First Name: Jason
Last Name: Bogstie
Re: Look normal?
Post by JBog » Sun Oct 10, 2021 8:06 pm
Thanks! What size bottoming tap?
Re: Look normal?
Post by Allan » Sun Oct 10, 2021 8:11 pm
You also have replacement one piece valves, so someone has definitely been in there before you. It looks good to go.
The tap size for the head bolt holes is 7/16" UNC.
First Name: Henry
Last Name: Lee
Re: Look normal?
Post by Henry K. Lee » Sun Oct 10, 2021 8:13 pm
7/16" X 14 NC thread.
Re: Look normal?
Post by RajoRacer » Sun Oct 10, 2021 8:53 pm
Get yourself one of these - Woodson tooling.
Last Name: Tannehill
Re: Look normal?
Post by JTT3 » Sun Oct 10, 2021 8:55 pm
Hank my man, correct as usual!
mbowen
First Name: Miles
Last Name: Bowen
Re: Look normal?
Post by mbowen » Sun Oct 10, 2021 10:00 pm
I just did mine today. I started with a standard tap, followed by a bottoming tap, then a 7/16 bronze bore brush. The bore brush got a noticeable of carbon even after the taps.
Miles
1924 Touring “Bonnie”
1925 Express Wagon “Clyde”
Re: Look normal?
Post by Mark Gregush » Mon Oct 11, 2021 12:20 am
Just using a bottoming tap will not clean out the compacted carbon and guck at the bottom. The tap will do a great job of compacting it even more. I use a drill smaller than the diameter of the hole and gently break up what is in the bottom. Don't force it, or you will need to seal the bolt threads when you go through the bottom of the hole into the water jacket. Done both by hand or with drill motor running slow. Then vacuum out the leavings.
