***1918-1822 Model TT Ruckstell Axle Differential Assembly**
VowellArt
First Name: Martynn
Last Name: Vowell
Board Member Since: 2012
Post by VowellArt » Thu Oct 14, 2021 4:34 pm
Does anybody know which part number go to which set of nuts? There is no description of where those two part numbers go....other than a rather muddy picture of no particular scale.
Also were the screws that held the differential housings together lock wired also?
Fun never quits!
First Name: Adrian
Last Name: Whiteman
Re: ***1918-1822 Model TT Ruckstell Axle Differential Assembly**
Post by A Whiteman » Fri Oct 15, 2021 4:16 am
Can't help with the numbers, but it is looking good!
The carrier for the 2 pinion shaft looks about right,
Cheers
Adrian
L.I. Tom
First Name: Thomas
Last Name: Pilz
* REQUIRED* Type and Year of Model Ts owned: 1921 roadster, 1923 roadster pickup
Post by L.I. Tom » Sun Oct 17, 2021 11:13 am
On these truck axle's does both axles use the ball bearing or only the rux side (I don't have the book but the fella that owns it does but I haven't looked at it yet). I thought I saw a video a while back were the original passenger side used an original bearing and thrust washer. If so does anyone know if those thrust washers available anywhere? I will be going over one of these this winter. Thank you for creating these beautiful breakdowns.
Tom
VowellArt
First Name: Martynn
Last Name: Vowell
Post by VowellArt » Sun Oct 17, 2021 7:51 pm
Tom, both sides have same Thrust Bearing P-1009.
Fun never quits!
L.I. Tom
First Name: Thomas
Last Name: Pilz
Post by L.I. Tom » Sun Oct 17, 2021 11:21 pm
Thank you very much for the reply and the photo.
Tom
