Generator cutout
Rod Petrie
Topic author - Posts: 88
- First Name: Rod
- Last Name: Petrie
- * REQUIRED* Type and Year of Model Ts owned: 1926 TT
- Last Name: Juhl
Re: Generator cutout
I think the one on the left is a John Regan voltage regulator. You might contact him (he's on this forum) and ask. I don't know about the other.
Art M
- First Name: Art
- Last Name: Mirtes
The one on the left can be normally repaired by cleaning the points,and adjust so that the points close at about 6.5 to 7 volts. I clean and check mine once a year.
It is simpler to use a diode, but they can fail and burn up the generator armature like what happened to me when I tried a diode
Art Mirtes
Art Mirtes
MichaelPawelek
- First Name: Michael
- Last Name: Pawelek
Ron Patterson
Art
The correct operate voltage for the reverse current cutout is 7.2 volts which is the charging voltge for a 6 Volt battey.
Ron Patterson
Ron Patterson
Art M
- First Name: Art
- Last Name: Mirtes
Ron,
Thanks or the info. Four years ago I guessed at the voltage. I used 4 d cell batteries at the time and it worked. I now have a very good laboratory grade dc power supply.
Art Mirtes 3
Art Mirtes 3
