Header Build and Firewall Dishing all in a Day!
Topic author - Posts: 5491
- First Name: Henry
- Last Name: Lee
- First Name: Henry
- Last Name: Lee
- First Name: Dallas
- Last Name: Landers
Re: Header Build and Firewall Dishing all in a Day!
Nice Hank! You make it look easy my friend.
- First Name: Keith
- Last Name: Townsend
Beautiful work!
Very nice! If I install the Chevrolet over head on my 1925, will need to do the same. I really like your approach. Thanks
Both are nice, clean work.
What fun.
What fun.
- First Name: Henry
- Last Name: Lee
More to add. Heavy support at the Y pipe to prevent metal fatigue.
Spark plug wire cross over duct when using an outside Magneto or distributor.
- First Name: Donnie
- Last Name: Brown
Very nice job. As a retired Boilermaker welder I understand the amount of grinding and polishing it takes to smooth out the weld zones. When I worked at the Nuclear power houses we had to make all our welds look like that. It's hard to see in the picture, but it appears you added a 1/4 turn "twist" to the lower header support. Little details like that make the brackets stronger and add one more little design feature to the project.. Again,very nice job .........
