Support Forum
Phillip
- First Name: Phillip
- Last Name: Lee
- * REQUIRED* Type and Year of Model Ts owned: 1927 Model T Roadster Pickup
Post
by Phillip » Wed Mar 27, 2019 4:17 pm
I have a 1927 roadster pickup. I am installing wood bands. The bands shown for a 1927 has one wide band. All 3 bands in mine are narrow. Can I cut the wide wood band down to size. It will still have the oil groves. My motor number is 4042906. Is mine not a 27 roadster? Has engine been changed out? Did some 27s have all narrow bands and some one wide. The band so have the removable ears. (FYI) I let one on the band slide around too far so I had to remove the hogs head.
pre15dale
- First Name: Dale
- Last Name: Kemmerer
- * REQUIRED* Type and Year of Model Ts owned: 1909 touring 1911 open runabout
Post
by pre15dale » Wed Mar 27, 2019 4:31 pm
That engine number would be may 26, 1920
Ruxstel24
- Last Name: Hanlon
Post
by Ruxstel24 » Wed Mar 27, 2019 5:19 pm
I recommend getting the correct brake band and not cutting it down.
If you cut it, the rivets and ears won't be centered anymore, unless you cut both sides.
Phillip
- Last Name: Lee
Post
by Phillip » Wed Mar 27, 2019 6:02 pm
The wood band is all that would need to be trimed. The wide wood band had 4 oil groves, if I trim at the 2 outside oil groves the inside 2 oil groves matches perfectly with the other 2 wood bands. All 3 steel bands are the narrow ones. When did Ford change to have one wide band?
Thanks very much for your replies and suggestions.
Post
by RajoRacer » Wed Mar 27, 2019 6:10 pm
The "Improved" 1926 (& '27) Ford had the new, wider brake band.
Phillip
- Last Name: Lee
Post
by Phillip » Wed Mar 27, 2019 6:13 pm
The VIN on the title is 14654880. Would this be a 1927 body with a 1920 engine?
Post
by DanTreace » Wed Mar 27, 2019 6:14 pm
Change to transmission brake band Aug 1, 1925
for the Improved Car.
- Last Name: House
Post
by George House » Wed Mar 27, 2019 6:21 pm
Philip,
You ordered wood bands based on the year model of your RPU and not engine/tranny. Yes your engine has been changed out and no; Ford didn’t make ‘27 models with some 3 narrow bands and some 2 narrow and one wide. Toward the end of Model year 1925 Ford introduced a wider service brake DRUM necessitating a wider brake band and slightly modified tranny cover. Some call it a hogshead but here in south Texas tamales are made from hogsheads. Simply get a 3rd narrow band - they’re proliferating in our garages - and call the wood band maker and buy a single narrow band....
Phillip
- Last Name: Lee
Post
by Phillip » Wed Apr 03, 2019 10:06 am
Got the wood bands installed. Took it for a short drive and they work great. I found it easier for me to remove first then remove and reinstall the starter. The best advice that I got was the dental floss to tie on the washers and nuts. I have a tendency to drop small parts. With the floss I was not worried about droping the washer. Did not drop anything. ( But wrenches, bolts, and lights when under the T)
Thanks again for all the help the forum give. There is a wealth of information for the asking.
Phillip
