Drive shaft/pinion taper?
Post by speedytinc » Sun Dec 12, 2021 5:06 pm
Some body out there knows the angle of the d/s pinion taper? Knowing is a step ahead of figuring it out. I am in the process of shortening some drive shafts for a muncie & jumbo giant transmissions & need to remake the end. Once I get the ends machined I will be lapping the gears to fit.
Thanks in advance.
Last Name: Humble
Board Member Since: 2006
Re: Drive shaft/pinion taper?
Post by Humblej » Sun Dec 12, 2021 5:21 pm
I do not know the answer to your question, but wouldnt the other end be easer to cut and machine?
Post by speedytinc » Sun Dec 12, 2021 5:33 pm
Of course, but this end is the bad one. I have the capability & no need to ruin a good one.
Pep C Strebeck
First Name: Joseph
Last Name: M
Post by Pep C Strebeck » Sun Dec 12, 2021 5:52 pm
I saved this from the forum, but I do not remember who posted it.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Sun Dec 12, 2021 6:03 pm
Thank you for the drawing. Probably will be useful in the future!
Post by speedytinc » Mon Dec 13, 2021 12:11 am
Thanks, thats very useful. More than I needed. Good to print & file away.
Interesting : u - joint pin hole 3/32? S/B 1/4"
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Mon Dec 13, 2021 7:45 am
John, the U-joint hole is 9/32".
Post by speedytinc » Mon Dec 13, 2021 8:37 am
I see. For some reason my work lap top shows it clearer than my home unit. Thanks
Post by Mark Gregush » Mon Dec 13, 2021 1:53 pm
When I did mine, I cut from the U-joint end, the shaft I was using was good at the pinion end. If I made the bushing area a little undersized (I did!), no problem, just made a new bushing to fit. Pinion end, would require more work; taper, thread, keyway and press fit for the pinion bearing. Even the modern replacement pinon bearing would still need about the same press fit, so the inner race does not spin. I had someone I know do the square end machining.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Mon Dec 13, 2021 11:21 pm
Actually the pinion taper is 3½" per ft on diameter. This taper has an included angle of 16.594 degrees.
