Support Forum
jwrightjr
- Last Name: Wright
- * REQUIRED* Type and Year of Model Ts owned: 1922 Touring, 1925 Roadster
Post
by jwrightjr » Fri Dec 17, 2021 5:56 pm
I bought my first T back in late 18 (2018 I'm not that dam old) not knowing anything about them. Since then old "Tinker" as well as the forum and a couple of local T owners (and now good friends) that literally hunted me down has taught me a lot about the cars and the "T" culture. I am not new to tearing apart engines and rebuilds but this is definitely a first for me. I am currently laid up from surgery so I decided to start working on one of the many spare engines I have acquired. Yes I said surgery and yes I know I should not be out in the workshop and no my wife is not home......
Anyway I got the engine up on the stand and dropped the pan and this is what I found.....
This is my first T engine tear down and it gave me a good chuckle so I thought I would share. Anybody else ever have a mouse house inside the pan?
- Mouse House
Kind Regards
John
1922 Touring "Tinker"
1925 Roadster "Pops" (Pile Of Parts)
Martin, Ohio
Les Schubert
- First Name: Les
- Last Name: Schubert
Post
by Les Schubert » Fri Dec 17, 2021 6:22 pm
Just be very careful and probably wear a mask as there is a fair risk of contracting HANTAVIRUS!
- Last Name: Humble
Post
by Humblej » Fri Dec 17, 2021 6:47 pm
Yes, I had that too on a spare engine. It must have gone in thru the oil filler cap opening. Ruined the crankshaft.
MichaelPawelek
- First Name: Michael
- Last Name: Pawelek
Post
by MichaelPawelek » Fri Dec 17, 2021 6:51 pm
Haven’t had the mouse problem but after having a Model T sit for two years in a barn that would not start found the whole carburetor filled with mud dauber nests…
Post
by RajoRacer » Fri Dec 17, 2021 7:23 pm
Discovered this in a freshly rebuilt engine that sat for several years - I won't "start" anyone's engine that been sitting for a spell without head & lower pan cover removal - not much into "surprises" !
Post
by John kuehn » Fri Dec 17, 2021 7:34 pm
We live on a farm and see this from time to time in old storage containers, bins and etc. Old engines are good places for mice and rats to make a home. Hard to get rid of them if your in the country like we are. Just use common sense when cleaning up their stuff and etc.
Old cars with the remains of headliners in them are the perfect place for them to build their nest and multiply.
You have to use bait or cats to keep them thinned down.
jwrightjr
- Last Name: Wright
Post
by jwrightjr » Sat Dec 18, 2021 10:13 am
This engine came from a barn in Michigan and was sealed up except for the starter and generator holes. The car I bought out of the same barn was ankle deep in nuts and mouse debris so shouldn't be too much of a surprise I guess. I have a couple radiators I picked up and it looks like they were knitting sweaters inside of them, industrious little bastards.
Kind Regards
John
Martin, Ohio
Post
by TWrenn » Sat Dec 18, 2021 10:17 am
Crazy what those critters can do in an engine aint it? And, small world, you live barely half an hour west of me. I'm in Erie County.
Maybe next year we can do some touring...we have a lot of guys around here with Ts and we're very active in touring.
Post
by Norman Kling » Sat Dec 18, 2021 10:54 am
Thanks for posting this. It would seem good to me for anyone who is going to install an engine which has been setting around, or even one in a car, unless everything is closed, to remove the inspection cover under the engine and over the transmission and be sure everything is clean before starting. Crankshafts are expensive and could even plug the oil line with debris and ruin the whole engine.
I haven't done that in the past, but only used one rebuilt engine which I bought at a swap meet and was lucky. All others I have installed have been recently pulled apart for repairs.
Post
by Steve Jelf » Sat Dec 18, 2021 11:05 am
I didn't try to start this one.
jwrightjr
- Last Name: Wright
Post
by jwrightjr » Sun Dec 19, 2021 11:09 am
Steve that's a different form of oil dry right there! Wonder if oil in pan would discourage them?. There was just a touch of oil in mine but it was back by the transmission in the sump and the nest was at the front. Steve's looks like a mouse condo community.
Kind Regards
John
Martin, Ohio
Post
by Norman Kling » Sun Dec 19, 2021 11:11 am
Are you sure that a varmint left that? Some old timers put oatmeal in the crankcase to quiet knocks!
ModelTWoods
- First Name: Terry
- Last Name: Woods
Post
by ModelTWoods » Sun Dec 19, 2021 12:02 pm
I've never had a mouse or mice in an engine, but back in 1965 when my Dad and I pulled my Grandfather's (my Dad's father) 27 coupe out of a barn on my Dad's farm, the mice had completely eaten and ruined what was left of the original interior. Cotton batting was everywhere in the car and it smelled to high heaven, the car had set undisturbed in that barn from 1951 (the last year it was licensed and driven by my Grandfather) for 14 years, until it was pulled into daylight in 1965. Even it it still ran (which it didn't), he would have needed to do a frame off restoration, just to get rid of the mouse smell.
