WANTED! 3-Z-686 or 5-Z-212 Body Bolt Wrench and 3-Z-1327 Steering Post Wrench
Topic author - Posts: 591
- First Name: Joseph
- Last Name: M
I am trying to find a couple of 3z/5Z tools; I would like to find a 3-Z-686 Body Bracket Bolt Holding Wrench (later versions are the 5-Z-212 and 5-Z-212-1), this is listed as being 23/32" and also a 5-Z-212-2 Body Bracket Bolt Holding Wrench, this one being listed as 21/32". And I would also like to find a 3-Z-1327 Steering Post Nut L Wrench. If anyone would happen to have any of these or may be able to put me in touch with someone that may have them, any and all help would be appreciated. The best/easiest way to contact me is through a Private Message here on the Forum, please let me know what you may have available. Thanks for looking.
Last edited by Pep C Strebeck on Thu Oct 06, 2022 3:32 pm, edited 1 time in total.
- First Name: Don
- Last Name: Kirtley
- * REQUIRED* Type and Year of Model Ts owned: 13 and 16 touring, 18 and 20 coup, 20 tudor
- Board Member Since: 2009
Re: WANTED! 3-Z-686 Body Bolt Wrench and 3-Z-1327 Steering Post Wrench
I have the 686 and 212 z tools you are looking for. Check your email. And call me. Don
- Last Name: M
Still looking:
3-Z-686 Body Bracket Bolt Wrench (or the later 5-Z-212 or 5-Z-212-1)
3-Z-1327 Steering Post L Wrench
Please let me know what you may have available, thank you for looking.
- Last Name: M
I don't have an image of the 3-z-1327 to share,but still looking for both a 3-Z-686 (or later 5-Z-212) and a 3-Z-1327.
- First Name: GG
- Last Name: Gregory
The body bolt Z wrench is a cool hard to find piece !
- Last Name: M
Still looking, any and all help is appreciated.
- Last Name: M
Back to the top.
- Last Name: M
Still looking, any help is appreciated.
- Last Name: M
Still in need. Please let me know if you may have one available.
- Last Name: M
Still looking for the 5-Z-212 or 3-Z-686 wrench.
- Last Name: M
Still in need of a wrench.
- Last Name: M
Still looking. Any help will be appreciated.
- Last Name: M
Once again, to the top. Still looking for a body bolt wrench, 3-Z-686 or 5-Z-212.
- Last Name: M
Re: WANTED! 3-Z-686 or 5-Z-212 Body Bolt Wrench and 3-Z-1327 Steering Post Wrench
Back to the top.
Good luck finding that wrench, Pep!
I've only seen one other and I own it.
- Last Name: Nunn
I have a 3-Z-686 wrench. Unfortunately, someone used a centerpunch to add his initials.
- Last Name: M
Thought I would pull this back up to the top. Still looking for the same wrench. Come on, somebody has to have one, anybody?
You'll probably have to make one out of a flare nut wrench.
