Fan reassembly
Petrah Phyre
First Name: Sean
Last Name: Pownall
* REQUIRED* Type and Year of Model Ts owned: 1926 Speedster
Fan reassembly
Post by Petrah Phyre » Thu Dec 23, 2021 5:04 pm
Just performed a clean up of my '26 fan assembly. I used moly bearing grease. Correct or no? My rear cap did not have a felt washer underneath. Is that required? Seems like it should help with grease loss.
Last Name: Humble
Board Member Since: 2006
Re: Fan reassembly
Post by Humblej » Thu Dec 23, 2021 5:59 pm
Sean, Ford used oil in the fan. The threaded hole on the fan is for the filler plug, many replace it with a zerk fitting and use grease. Both oil and grease work out of the rear of the fan shaft and make a mess on the inside of the hood. The felt washer is the seal, essential when using oil, but it slows down the grease leaking out too.
Re: Fan reassembly
Post by TXGOAT2 » Thu Dec 23, 2021 7:10 pm
I like moly grease, especially for chassis lubrication, but it might not be best for a brass bushing, since it has sulphur or sulphide in it. (MO2S (?) I'd use red grease and a felt seal. The best solution is the ball bearing hub.
Re: Fan reassembly
Post by Mark Gregush » Thu Dec 23, 2021 7:19 pm
Stick with oil. Grease just does stick around between the shaft and brass bushings. Some use motor oil, me and others, a heavier lube like 600w or even chainsaw bar lube. I tried grease, my fan let me know it did not like it! :?
Re: Fan reassembly
Post by TXGOAT2 » Thu Dec 23, 2021 8:10 pm
Ford used oil lubed fan hubs up to about 1950.
Petrah Phyre
First Name: Sean
Last Name: Pownall
Re: Fan reassembly
Post by Petrah Phyre » Thu Dec 23, 2021 9:19 pm
Thank you for the insight. Looks like it's coming apart again. Good thing I like to turn screws. I will get the felt and switch to oil. :)
Last Name: Humble
Re: Fan reassembly
Post by Humblej » Fri Dec 24, 2021 8:39 am
Order the oil filler plug also.
Harry Lillo
First Name: Harry
Last Name: Lillo
Re: Fan reassembly
Post by Harry Lillo » Fri Dec 24, 2021 10:50 am
I have a question?
If all Model T fan hubs were to be oiled why is there a drilled hole from the back of the hub shaft to a
the center of the shaft?
I was working on my small diameter fan pulley last night and was contemplating how it would be lubricated
with grease. Another parts shaft from my inventory had an interesting grease cup on the rear.
It was a locking nut/ grease cup combination.
Very clearly, this unit was designed to use grease to lubricate the shaft.
Harry Lillo
Calgary
jab35
Last Name: Bartsch
Re: Fan reassembly
Post by jab35 » Fri Dec 24, 2021 10:58 am
The early versions had a grease cup at the end of the fan axle, later '26-7 for sure had the oil plug. I use chainsaw bar oil, fwiw. jb
Re: Fan reassembly
Post by Mark Gregush » Fri Dec 24, 2021 11:08 am
Good question Harry. Could it have to do with where the grease would come out on the shaft or how often that style required greasing? The hole where the grease comes into the housing is in between the bushings on the early style with the grease cup, along with the front not being sealed, so grease can flow better to the front.
The later style redesigned hub, the grease would fill the cavity behind the bushings and would require more turns of a grease cup to get grease to the front bushing, so Ford went with oil, felt seal at the rear and paper gasket on the front in an attempt to keep things lubed and cleaner. (?)
Guess Ford could have kept the grease cup on the shaft like before, but this could have been a cost savings to just use oil and simple plug.
Last Name: Humble
Re: Fan reassembly
Post by Humblej » Fri Dec 24, 2021 11:35 am
Harry, this was never an "all model T's" discussion. Original post is in regards to the 26-27 fan. There is an oil filled fan hub on my 1926, and my 1924 too, so it has applicability to more than just the improved Fords, but not all model T's.
Re: Fan reassembly
Post by TXGOAT2 » Fri Dec 24, 2021 12:04 pm
I believe that oil is best for bushings that run at higher speeds. Ideally, a bushing will have some kind of oil reservoir to assure a continouous supply.
Petrah Phyre
First Name: Sean
Last Name: Pownall
Re: Fan reassembly
Post by Petrah Phyre » Fri Dec 24, 2021 12:10 pm
My hub has a "t-handled" plug in the fill hole with a spring loaded ball for adding lube without removal. I put grease back in because it was what I took out. Though this could just be oil drying out after 20+ years of sitting. I will go with changing out to a heavy weight oil if that's the way Henry wanted it.
Re: Fan reassembly
Post by Mark Gregush » Fri Dec 24, 2021 12:43 pm
Larry brings up the early style using grease because that is part of the discussion about what lube to use RE people using grease instead of oil in the later style fan hubs.
Last Name: Humble
Re: Fan reassembly
Post by Humblej » Fri Dec 24, 2021 1:03 pm
Sean, that T shaped ballbearing plug is an early grease gun fitting. Unscrew that and replace it with a oil fill plug available from the usual vendors.
Petrah Phyre
First Name: Sean
Last Name: Pownall
Re: Fan reassembly
Post by Petrah Phyre » Fri Dec 24, 2021 1:14 pm
Thanks Jeff, will do.
Last Name: Humble
Re: Fan reassembly
Post by Humblej » Fri Dec 24, 2021 1:20 pm
Sean, one more thing. There should be a paper gasket between the fan hub and the fan blade, that needs to be an oil leak proof connection. If you or a previous owner ever took the fan blades off that gasket needs to be replaced and I recommend using non hardening #2 gasket sealer there too.
Petrah Phyre
First Name: Sean
Last Name: Pownall
Re: Fan reassembly
Post by Petrah Phyre » Fri Dec 24, 2021 4:53 pm
There was not a gasket, so I made one. I will order a manufactured one when I order the plug. So many things to do after a 20+ year rest. No compression on a couple of cylinders and looking through the plug holes, it still has the two piece valves. As you know...this will get costly as I keep digging deeper.
Re: Fan reassembly
Post by RajoRacer » Fri Dec 24, 2021 4:58 pm
I compare MOST Model T's to that of an ordinary (yea, right) plumbing job - might as well do it all or you'll have a leak farther down the line !!!
Last Name: Patrick
Re: Fan reassembly
Post by jiminbartow » Sat Dec 25, 2021 10:21 am
Yes the felt is necessary to keep dust out and oil in. Grease is not what Ford intended the new 1926 - ‘27 fan to be lubricated with. There is an oil reservoir just behind the fan with a flanged shaft with a hole through the center that directs the oil from the oil reservoir to the pressed in front and rear bushings inside of the housing. If you use grease it will block the shaft inlet hole in the flange inside the reservoir and not allow the oil through the shaft, depriving the two bushings of lubrication. Occasionally check and keep the reservoir filled with oil. Jim Patrick
Re: Fan reassembly
Post by TXGOAT2 » Sat Dec 25, 2021 10:47 am
I suspect that the oil reservoir is not intended to be filled to the top. I would think that using an oil can to add some oil to the reservoir, then turning the hub to position the fill hole just slightly below the axis centerline and allowing any excess oil to drain into a small container would give the best results. That should allow oil to be available to the bushing when the engine is running, yet not leak out when the engine is stopped. A 10W 30 oil might work best here, since it could flow when cold. Removing the fan belt during the filling procedure would prevent oiling it and would permit checking the bushing for wear. My fan hub has a brass plug in it with an allen wrench socket.
Last Name: Patrick
Re: Fan reassembly
Post by jiminbartow » Sat Dec 25, 2021 11:03 am
I have always filled mine to the top as much as it will hold. As the shaft turns, if there is any space inside the space between the bushings, the hole inside the center of the shaft, that transports oil between the center shaft oil tube and the bushing space pulls the oil into the space through centrifugal force, thus pulling more oil into the shaft, until there is no more room in the space between the bushings. Jim Patrick
Re: Fan reassembly
Post by TXGOAT2 » Sat Dec 25, 2021 11:08 am
If it doesn't leak to the point of being a nuisance, that's fine. When the engine is running at speed, the fan tends to move forward on the shaft, which would encourage oil to escape from the space between the bushings back into the reservoir. The hole drilled in the shaft would allow oil to return to the space between the bushings. At low engine speeds, the fan usually tends to move back and forth on the shaft slightly, which promotes oil distribution. A worn hub with significant foraward-backward slack would probably tend to leak excessively.
halftracknut
First Name: randy
Last Name: lee
* REQUIRED* Type and Year of Model Ts owned: 1926 pickup
Re: Fan reassembly
Post by halftracknut » Sat Dec 25, 2021 11:13 am
Ok, I will be the bad guy here sorry. Most of the T's I have found have a worn fan shaft and pulley and puke out whatever you lube you put in them..My case is this, I bought a new radiator from brass works and was running what I thought was a good fan setup after reading another post here I checked it out again a no lube and worn shaft and pulley ....so with a new $800 radiator rather than run the risk of major failure I bought a new set up with a sealed bearing and new pulley...also drilled the new shaft and put a cotter key in it....now I sleep good at night.....Merry Christmas....
Re: Fan reassembly
Post by TXGOAT2 » Sat Dec 25, 2021 11:19 am
I think the sealed hub is the best solution for a car that is driven a lot and for cars that are run at higher speeds. Given the cost of radiators, any hub ought to be checked frequently for indications of wear or lack of lube. The fan itself needs to be in good condition, with all blades at the same pitch, running in the same plane, and in good balance.
Last Name: Patrick
Re: Fan reassembly
Post by jiminbartow » Sat Dec 25, 2021 12:31 pm
I rebuilt mine. New shaft and new pressed in bushings.
