Which way should the blade cut?
Topic author - Posts: 7360
Should the teeth cut when pushing, when pulling, or does it matter?
				Les Schubert
 - First Name: Les
 - Last Name: Schubert
Re: Which way should the blade cut?
Normally when pulling
Ruxstel24
 - Last Name: Hanlon
I would think when pushing, most hand saws do.
				George Andreasen
 - Last Name: Andreasen
 - * REQUIRED* Type and Year of Model Ts owned: 0...building from parts
Ironic............I just junked a perfectly good Keller because I couldn't even GIVE it away......
Rotate the motor pulley by hand while carefully watching the blade. It should RAISE perceptibly on the return stroke, not cutting stroke, which saves the teeth.
Or, if you seem to be going through blades way too fast, turn them around.
Les is correct...cut on the pull, and George is correct in that there should be a cam which lifts the blade up a little for the return (outward) stroke
				Sparknwire
 - First Name: RJ
 - Last Name: Lucyszyn
 - * REQUIRED* Type and Year of Model Ts owned: 1913 Speedster
Teeth toward the back of the saw
				Roz
 - First Name: Dennis
 - Last Name: P
 - * REQUIRED* Type and Year of Model Ts owned: 1926 Ford Touring Car
 - Board Member Since: 2014
It should turn ccw as you are looking at the blade side of the saw, and cut on the pulling stroke. Those are good saws. When the blade wears out, you can make several nice knife blades from it.
John E. Guitar
 - Last Name: Guitar
 - Board Member Since: 2012
The old blades also make great gasket scrapers.
Ruxstel24
 - Last Name: Hanlon
A little drift...
One of the best gasket scrapers I had was a kitchen knife ground square. Got in narrow places great.
I don't think the ex even missed it
kelly mt
 - Last Name: Kelly
My old Marvel #2 saw lifts the blade on the forward stroke.
My transmission drum balancing rig has two such blades with the back of the blade ground almost to a knife edge, on which the axle in the mandrels runs.
Barth_Tool_Co
 - First Name: Jason
 - Last Name: Alvord
 - * REQUIRED* Type and Year of Model Ts owned: '26 Touring
My Marvel 9A cuts on the pull, teeth on the blade face towards the back of the saw. The manual states this is correct for that saw.
These are neat tools, fun to watch!
... and my number is Beechwood 4-5789
1926 Touring - "Corrina"
Barth_Tool_Co
 - First Name: Jason
 - Last Name: Alvord
So does my Marvel 9A.
The Keller is less sophisticated than the Marvel. The blade rests on the work in both directions.
Barth_Tool_Co
 - First Name: Jason
 - Last Name: Alvord
Out of curiosity Steve, how many teeth per inch on the blade you're running?...Steve Jelf wrote: ↑Tue Apr 02, 2019 2:14 pmThe Keller is less sophisticated than the Marvel. The blade rests on the work in both directions.
Walter Higgins
 - First Name: Walter
 - Last Name: Higgins
The cutting load should be applied to the stationary jaw.
kelly mt
 - Last Name: Kelly
Where are you guys finding blades? I found some good quality fine blades but no course blades. I forget the TPI.
The blades I'm using are 10 TPI Vanguard, made in England.
