Does anyone know what these are?
Topic author - Posts: 2437
- Last Name: Patrick
I purchased a bag of these several years ago. I thought they were emergency brake lever springs, but When I attempted to fit one on the emergency brake handle of my coupe, I could not figure how it fit on so it would apply tension to the closed handle so that it would open back up. Can anyone confirm that this is what it is, or if it is for something else, Please clue me in. Thank you. Jim Patrick
- First Name: Trent
- Last Name: Boggess
Re: Does anyone know what these are?
Brake rod anti-rattlers.
Respectfully Submitted,
Trent Boggess
Trent Boggess
- First Name: Jim
- Last Name: Sims
- * REQUIRED* Type and Year of Model Ts owned: 17 touring 20 roadster 21coupe 25tudor 25 pickup 27 coupe
Anti rattlers for the spark and throttle rods.
Without anything to indicate size, I thought they were tie rod groove-wearers.
- First Name: Bryant
- Last Name: Shafer
The shape is similar to how many of the ant-rattlers are design BUT the ends of the arms don't match any. I wasn't able to find a picture of Baby Giants, so unresolved
- Last Name: Morsher
They are what Prof Trent said.
- First Name: Dick
- Last Name: Fischer
- * REQUIRED* Type and Year of Model Ts owned: 1912 Touring
When I was a kid my Uncle George (B.1908) called them "Antler Rattlers". I was an aduIt before ever hearing the proper name.
To this day I have to be on guard to not say, "antler rattler". It just slides off the tongue so smoothly. I'll bet he wasn't the only one who called them by that name.
Dick
Dick
Frank, in the bottom right corner of the first group of pictures, looks exactly like what I have. Do you know what those go on? Jim Patrick
That insert was JP's I added it just for comparison to the othersjiminbartow wrote: ↑Sun Feb 20, 2022 11:50 pmFrank, in the bottom right corner of the first group of pictures, looks exactly like what I have. Do you know what those go on? Jim Patrick
Oh. I was excited about looking at my own picture. LOL! For those needing a size reference, each leg of the thing is about 3” long and the wires are about 1/2 apart. I’m sure it is an anti rattler, as suggested. Just need to know what rattle it is designed to quiet. It is not a strong spring, like one that would be required to quiet the front tie Rod or steering rod. The loop, or bent portion that are facing eachother in the picture is about the size of an emergency brake rod or the spark and throttle rods. Jim Patrick
Prof. of All Things Model T Trent Boggess already called it in the first reply.
Those short wrap around spring anti rattlers are for the brake rod clevis, to stop the noise.
Likely another brand than the famous Baby Giants as those use a double loop, so the versions you have with single loop are just a competitor.
Could be these Samson brand? The larger tie rod version has only 2 loops. The Samson Jr. brake rod silencers aren't pictured.
- First Name: Noel
- Last Name: Chicoine
If a Model T doesn't rattle, is it still a Model T?
