Do I Need To Prime These Parts
Topic author - Posts: 892
- First Name: Bruce
- Last Name: Brakke
These window trim pieces, for my 1927 coupe, have been blast cleaned by crushed glass. I intend to paint them by foam brush using Rust-Oleum Protective Enamel in gloss black. Do I need to prime them? I have Rust-Oleum Rusty Metal Primer that I could use. I am thinking that the advantage of using just one coat would reduce the chance of showing brush strokes.
The pieces have been hand sanded using 220 grit paper, except for the one on the right in the third photo and the last photo.
- First Name: Val
- Last Name: Soupios
Re: Do I Need To Prime These Parts
I use Rustoleum primer, filler first. It drys fast can be sanded to achieve a mirror finish when top coated with Rustoleum rattle can black, gloss enamel. I get great results and don't have to worry about brush strokes.
That looks like a rough finish needing some build up & smoothing. If it were not rough, I would give it a coat of flat black spray paint as a base to help adhesion & finish coverage.
If the above mentioned primer is dark grey or black - yes. If light grey.
Any chips show up loudly.
- First Name: Bruce
- Last Name: Brakke
John, The 220 sanded areas are not rough.
- Last Name: Wrenn
Those pieces look kinda rough in the pics. Here's one of the interior trim pieces on my '25/'26 Fordor that were restored probably better than from factory new. The pic doesn't do them justice. Smooth as a baby's behind and shine like a mirror. Someone did an outstanding job on this entire car.
- First Name: Bruce
- Last Name: Brakke
The piece on the right in the third photo has not been sanded and piece in the last photo has not been sanded.
- Last Name: Patrick
Typical sandblast damage. You could sand a board with that rough surface! Awful!
Yes, prime them. Use a very dark primer, like black, for the reason John mentioned. Sand with a fine grit (at least 800), and finish with your gloss black. I would use spray rather than brush.
Unless the primer you use is somehow incompatible with subsequent top coats, I would always recommend s primer for a better job.
- First Name: Bruce
- Last Name: Brakke
Pieces hand sanded with 220 grit and ready to prime. Smooth as a baby's behind. Can't sand wood with them now. Nice.
- Last Name: Codman
I agree with Steve. I would use Rust0leum appliance Black. In my opinion it has a smoother finish and brighter shine then the regular rust0leum.Steve Jelf wrote: ↑Wed Mar 02, 2022 1:34 amYes, prime them. Use a very dark primer, like black, for the reason John mentioned. Sand with a fine grit (at least 800), and finish with your gloss black. I would use spray rather than brush.
