'26 block to hogshead bolts/shims
Petrah Phyre
Topic author - Posts: 162
- First Name: Sean
- Last Name: Pownall
- * REQUIRED* Type and Year of Model Ts owned: 1926 Speedster
Received my car with the bolts and shims missing between the block and hogshead. I can figure out the bolt size, but do you use feeler guages to determine shim thickness? Do you need to use the stator shims...?
Alan Long
- First Name: Alan
- Last Name: Long
Re: '26 block to hogshead bolts/shims
You may not need shims at all. It will depend on the condition of the Sump and how bent it is, if at all.
I’d start by bolting up the Pigs Head without shims and see where the 4th main Bearing is in relation to the transmission output shaft. My 26 doesn’t have any Shims
Alan in Western Australia
varmint
- First Name: Vernon
- Last Name: Worley
http://www.mtfca.com/discus/messages/25 ... 1329345647
http://www.mtfca.com/discus/messages/17 ... 1297559856
Also the club book, "The Model T Ford Transmission"
Vern (Vieux Carre)
Petrah Phyre
- First Name: Sean
Thank you all. I hav a plan now.
I don't know whether or not the engine is in the car, but the best way to align it is with the engine out on an engine stand where you can rotate the engine with the nose down. Then you take the 4th main with two bolts started through the crankcase and see if you can move the 4th main in and out using the bolts as your guide. It should not bind on the output shaft. You can then add or remove shims to change the alignment so it fits without binding.
