Ball cap , re-babbitted and bored to Std. or your specified diameter
Gene_French
First Name: Gene
Last Name: French
Board Member Since: 2014
Post by Gene_French » Tue Jan 29, 2019 6:07 pm
Model T Ford ball cap , re-babbitted and finish machined to standard diameter or your specified diameter … ball caps are sold outright with NO EXCHANGE necessary … price is $45 plus $13.60 priority mail postage in lower 48 states … actual postage outside this area or international … Gene French 49519 cr.23 Nunn, Co. 80648 phone 970-581-2808
Gene_French
First Name: Gene
Last Name: French
Re: Ball cap , re-babbitted and bored to Std. or your specified diameter
Post by Gene_French » Wed Jan 30, 2019 6:18 pm
can bore the ball cap on any size as needed … I recommend .002" clearance over clutch plate shaft diameter ...gene French 970-581-2808
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sat Feb 02, 2019 10:10 am
Gentlemen:
can deliver to Chickaha Swapmeet March 15-16 … will be at space SL4 in south building ...always an optimist Gene French 970-581-2808
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Tue Feb 19, 2019 9:40 am
top
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sat Mar 09, 2019 10:49 am
top
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Thu Apr 04, 2019 10:27 am
top
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Fri May 03, 2019 9:36 am
top
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Tue May 28, 2019 10:13 pm
top
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Tue Jul 02, 2019 8:37 pm
top
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Thu Aug 08, 2019 3:23 pm
top
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Fri Oct 11, 2019 11:58 am
top
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Mon Dec 02, 2019 8:06 pm
top... purchased a quantity of ball caps for re-Babbitt ...
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sun Jan 12, 2020 9:55 am
top
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sat Mar 21, 2020 10:01 am
to the top again , thanks MTFCA
Marshall V. Daut
First Name: Marshall
Last Name: Daut
Post by Marshall V. Daut » Wed Apr 01, 2020 8:24 am
Hey, Gene! We're sending you an order. Is that street address complete? 'Seems like something is missing: 49519 cr.23.
Marshall
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Tue Apr 14, 2020 7:42 pm
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Fri May 08, 2020 9:03 am
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sun Oct 25, 2020 10:49 am
Post by Original Smith » Sun Oct 25, 2020 11:37 am
Gene: Why not think about rebabbiting camshaft bearings?
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sun Oct 25, 2020 4:12 pm
Larry:
i have re-babbitted cam bearings for my own use ... this requires that you start with good shells , the bearing halves are often worn out of round on the outside diameter ... this condition and any wear in the bearing bore of the block makes for a loose bearing ... also , the difficulty in getting an ample supply of good cores make this an unattractive venture ... always an optimist ...Gene French
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sat Jan 02, 2021 9:38 am
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sun Apr 17, 2022 9:55 am
to the top again ...thank you MTFCA
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sun Apr 17, 2022 10:13 am
the current pricing on the re-babbitted ball caps is $50.00 plus $16.20 postage in lower 48 states ... actual postage outside this area ... always an optimist ...Gene French
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sat Nov 26, 2022 10:29 am
to the top again ...thanks MTFCA
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Sun Jan 08, 2023 9:57 am
Gene_French
First Name: Gene
Last Name: French
Post by Gene_French » Tue Feb 21, 2023 10:30 am
