Wavy Piston Ring Question
Myxr6turbo
Topic author - Posts: 89
- First Name: Shawn
- Last Name: Barnard
- * REQUIRED* Type and Year of Model Ts owned: 1926 coupe
I have tried google but can't find much. What orientation should the piston ring be compared to the wavy ring under it? 180?
Thanks,
Thanks,
Re: Wavy Piston Ring Question
the ends 180 from ring opening.
Myxr6turbo
- First Name: Shawn
Thanks for that. Could the ring move around and possible cause the wavy ring to slightly come out as shown in the photo and score the bore?
I suppose it could move, but that doesn't seem to be a problem with most ring sets. At one time, it was common practice to "pin" piston rings to prevent them from shifting around in the grooves. I think that caused more problems than it solved, with pins coming loose and uneven wear. If you can determine the mfr of your ring set, it would be a good idea to cee if any specific information is available relating to installation. Some mfr websites offer a lot of information, some do not.
Kerry
- Last Name: van Ekeren
You will find that the wave spring behind the ring was fitted as a patch up rebuild at one time for a worn bore.
Could rotate, but ring gap being so small when compressed in the bore, it should not be able to get outMyxr6turbo wrote: ↑Sun May 01, 2022 10:57 pmThanks for that. Could the ring move around and possible cause the wavy ring to slightly come out as shown in the photo and score the bore?
Myxr6turbo
- First Name: Shawn
Thanks everyone. I'll put the wave spring 180 to the outer spring.
Are you re-assembling an engine with used rings?
