I have a seat cushion spring that measures abour 41" wide, 16-1/2" deep and 5" high. The back corners are more rounded than the front. Any idea of what years of what body this may fit? Thanks.
Keith
Mystery seat spring?
Topic author - Posts: 1426
- First Name: Keith
- Last Name: Townsend
Re: Mystery seat spring?
Pretty close to a low cowl touring front spring by the looks of it.
Call Snyder’s and give them the size and they can probably tell you. They make all kinds of T springs and have been for years.
- Last Name: Bartsch
KW:
Here's an earlier post that might help, viewtopic.php?t=23333 Good luck, jb
- Last Name: Patrick
Does that tag on the right side tell what it’s for?
- Last Name: Strange
- Board Member Since: 2013
The dimensions you gave don't match any of the spring packs that I bought from Snyder's for my 1925 Touring body.
- First Name: Keith
Here is the tag:
Your guess is as good as mine.
The spring does NOT have the channel to crimp upholstery into.
No crimping place means it could be a back spring instead of a seat? For a T or??
