Replacing Transmission Spring
Sam_Mendenhall
First Name: Sam
Last Name: Mendenhall
* REQUIRED* Type and Year of Model Ts owned: 14 Speedster
Board Member Since: 2014
Post by Sam_Mendenhall » Sun Apr 07, 2019 1:34 pm
Has anyone replace transmission spring without pulling the engine. I have heard you can pull the rear end, would the hogs head have to be removed? If you have done this I would sure like your opinion, pull the engine or not. Thanks Sam
Re: Replacing Transmission Spring
Post by Scott_Conger » Sun Apr 07, 2019 2:42 pm
It can be done but is not easy and can be a bear to do. If your spring is broken, the removal should be easier than the installation, so perhaps it will only be 1/2 of a bear or perhaps a bear CUB. Compressing the spring, lining the coils up to put the pin in is the trick.
Do it and come back and let us know if you're willing to do it again! :D
Post by John kuehn » Sun Apr 07, 2019 3:11 pm
The Ford Model T service manual explains how to do it.
Page 139. Beginning at paragraph 547 thru 561. Not one of the easier jobs to do but probably done this way at Fords service centers back in the day.
Post by Jerry VanOoteghem » Sun Apr 07, 2019 7:22 pm
Referring to your related posting on your clutch problem, have even positively determined that the spring is broken? The spring retainer can also break, which could also the cause of your trouble. This why I suggest you post a photo of what you're seeing with your trans cover removed.
Dennis_Brown
Last Name: Brown
* REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
Post by Dennis_Brown » Mon Apr 08, 2019 10:23 pm
I would pull the hothead first and get a good look at things to really locate the problem. I have heard of folks removing all than bolts and leaving a couple connected loosely in the front and lifting the rear of the engine- transmission so they could do work on the transmission.. Seems it would be easier to pull the engine and be able to work on it out in the open and not fight working in a confined space inside the body.
Sam_Mendenhall
First Name: Sam
Post by Sam_Mendenhall » Tue Apr 16, 2019 10:30 am
It was not the spring after all. I had to adjust the
fingers twice and finally got a high gear and good neutral. Thanks guys for your time and info.
Sam
Post by Steve Jelf » Tue Apr 16, 2019 11:21 am
Seems it would be easier to pull the engine and be able to work on it out in the open...
I believe I once saw a comment by Royce that he had replaced a spring through the back, with the engine in the car, and would never do it again.
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Sat Apr 20, 2019 8:09 am
"Tinkering Ted" Aschman has a procedure in one of his two books on how to replace that spring without removing the engine.
