Moving on to the next piece and hit a snag
Topic author - Posts: 415
- Last Name: Foye
- * REQUIRED* Type and Year of Model Ts owned: 27 Fordor, 15 speedster (2), 23 touring, 26 fordor, 25 TT
Can someone tell me what the diameter of an early fan is? Brass car, bent arm. I have one that was chopped and welded and most likely out of balance (and I can't find my tool to check it) and a bunch of later fan blades that are not going to fit. Plan is to MAYBE to cut down a later one as I have a needle bearing hub here. Just need to know the proper diameter to clear the radiator that I don't have on an engine I have not rebuilt yet...
Gen III Antique Auto - we do Model T Ford Restorations
You can have everything in life you want, if you will just help other people get what they want -Zig Z.
https://www.youtube.com/channel/UCeROBg ... pB-KImprjw
- First Name: Keith
- Last Name: Townsend
Re: Moving on to the next piece and hit a snag
Fan blades measure 13" tip to tip.
- Last Name: Foye
What year? And Thank you!!!!
- Last Name: Foye
Put another video out regarding the start of my fan adventure. I really thought I had an early one in that bucket. :/ Now I have two choices - cut a big one down or beg and barter for the right one... Got a couple "what did this come off of" units in this video. Anyone know what they fit?
https://youtu.be/zpBV7OrEw5I
If you are mixing fan pulleys, keep in mind fan speed.
Beside the measurement from "tip to tip", you need to measure from the center so that they will all be the same length from the hub and that they will balance.
- Last Name: Foye
"mixing pulleys" - you must be psychic cause I just shot the fan video, with the measurements above (13") - I found an oddball that I think my grandfather made up and it had a 13" blade on it. I assume it was for his '11 - we were messing around with it in the 80's and 90's a lot - v belts, rubber engine mounts, on and on. I should have that video out next week if the world doesnt end.
Every riveted fan you pulled out of that can will fit a car that has a brass radiator regardless of whether or not the hub is brass or not.
- Last Name: House
Every 16 rivet fan you pulled out will fit a brass radiator T. Make sure there’s no loose rivets tho’.
- Last Name: Foye
Thanks guys - the cut down one threw me off!
- First Name: DAN
- Last Name: MCEACHERN
Just be aware that needle bearing hubs are a disaster waiting to happen if the fan shaft is soft, (and all the stock shafts are soft). If you can file the shaft, its too soft to run a needle bearing on. Just something to be aware of. Needle bearings are great if used properly and a disaster if installed where they don't belong.
