Wiring Question
Topic author - Posts: 570
- First Name: Tad
- Last Name: Glahn
- * REQUIRED* Type and Year of Model Ts owned: 1925 Coupe, 1926 TT Closed Cab, 2 1924 Runabouts
Wiring Question
Here is a silly question from someone with no electrical skill:
Is there a technical difference between Model T spark plug wires and the rest of the wiring (Other than gauge)? If not, what gauge should the spark plug wires be?
I ask because I am making my own wires for a distributor, I will be using cloth braided wire.
Re: Wiring Question
Measure your distributor feed throughs ID for diameter (7 or 8mm) and order that specific diameter spark plug wire.
don't try to use "any old wire"...there are many proper, braided-cover spark plug wires out there available in bulk lengths
make sure they have a solid copper core and not graphite
if not available locally, the internet will be your friend
- First Name: Michael
- Last Name: Pawelek
- First Name: Tad
- Last Name: Glahn
Re: Wiring Question
Thank you Mr. Conger, that's just what I needed to know.
The barbed wire adds a nice rustic touch.
Re: Wiring Question
When using custom spark plug wires it's nice to have a colorful variety of plugs.
