So what size are the spare tire carrier nuts
Topic author - Posts: 1158
- Last Name: Govoni
I'm trying to attach the spare tire carrier to the goose neck on my 26 Touring. The three studs look like 1/2 x20 fine threads. Is this correct? I've read that the original ones were a thin nut. Fact or fiction.
What about the bolt that holds the rim on? Looks like a 3/8 x 24?
- Last Name: Govoni
Re: So what size are the spare tire carrier nuts
Come on now. Someone help me with my nuts.
- Last Name: C
And Dan Hatch in the classifieds said:
Re: spare tire carrier 21" (Melba Nolan's posting)
Post by Dan Hatch » Tue Sep 27, 2022 1:25 pm
The little thin nuts wired to it are hard to find.
- Last Name: Govoni
I saw his post. I wonder if the thin nuts have a strange thread as well.
- Last Name: Govoni
Sorry What is nf?
- Last Name: Strange
I think your answers to our questions are in this link viewtopic.php?t=23470Mopar_man wrote: ↑Sat Nov 05, 2022 7:52 pmI'm trying to attach the spare tire carrier to the goose neck on my 26 Touring. The three studs look like 1/2 x20 fine threads. Is this correct? I've read that the original ones were a thin nut. Fact or fiction.
Appear to be lug nuts
- Last Name: Bartsch
The thin stud nuts are relatively simple to reproduce by facing off and contouring regular 1/2-20 grade 5 nuts in the lathe. In a pinch the nut could be screwed on the bolt a couple turns and the face contoured by grinding, a little tedious but do-able. ymmv, jb
- First Name: Michael
- Last Name: Deichmann
If you have one or have a good friend that have one. Not everyone have that privilege and then it might be tricky...
Ford Model T 1914 Touring
- Last Name: Govoni
I'm going to look again in my pile of nuts that came with he car first. If not I'll order some. Not sure why I couldn't find them on Lang's WEB page. Thanks everyone!!
They are a very thin nut indeed & I've not seen them reproduced. I believe I have some to measure - be back later today.
You may also be able to find these nuts at an automotive parts store in the Trailer parts section 1/2"-20 Thread with 60° cone
But searching costs time & gas ($). I assume that the top shorter height nut just needs to be flush with the stud
I apologize Frank - it seems as though Lang's does carry a facsimile !
- Last Name: Govoni
Thanks Frank. I called Lang's they have them on backorder. I'm going to try the place you got the picture from.
- Last Name: Hjortnaes
You can see they are rounded on one side to fit the carrier.
